OT - lots of driving and enough of drilling - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-04-2007, 11:40 PM Thread Starter
Journeyman
Hey,
I will soon be moving from Philadelphia, PA to Atlanta, GA. This entails a small caravan of me in the wrangler and the wife and kid in the cherokee. I figure the 1/2 point to be around Durham. Can anyone recommend a hotel to stay at and a restaraunt for dinner?
Also, does anyone have any tips on doing a tap for the first time. I broke a torx bolt off on my door and my kindly neighbor "helped" me by drilling into the remaining shaft of the bolt to free it, only to leave me with bolt remains in the screw traces. I've never had a chance to do it before and wanted to get some recommendations.
Thanks,
Mick
unclmick is offline
post #2 of (permalink) Old 01-05-2007, 06:14 AM
Caver Dave's Avatar
Re: OT - lots of driving and enough of drilling
I'd skip Durham and push on to Greensboro... less chance of being caught without your body armor & sidearm [img]/ubbthreads/images/graemlins/shocked.gif[/img] and many more lodging choices!
So, the "good samaritan neighbor" strikes again!
IF the hole he drilled in the shank is centered... use a larger bit to remove *most* of the bolt (leave the threads intact) and tap using the correct size tap & some lube. Do it *manually* and make sure it's perfectly square when it starts to bite so you don't crossthread and lose what you have...
IF it's NOT centered, you'll have to open it up as well as you can (without getting into the threads)... Sometimes you'll end up with a "half moon" slug left that can be picked/pried out... then just chase with the correct tap.
Where you headed in Atlanta? Southern Jeeps is a good club in that area... great folks (except for Herb that doesn't come around here anymore! [img]/ubbthreads/images/graemlins/wink.gif[/img] )
Caver Dave is offline
post #3 of (permalink) Old 01-05-2007, 06:37 AM
lomodyj's Avatar
Ditto on the Durham advice.
There are a couple of hotels in Hillsborough (just west of Durham) that are reasonable price and not gonna give you a disease. I'll get a list for you over the weekend. Couple of good resturants in Hillsborough or you can drop 15 minutes south to Chapel Hill/Carrboro and have a plethora to choose from. When you coming through?
lomodyj is offline
post #4 of (permalink) Old 01-05-2007, 08:25 AM
mbalbritton's Avatar
Hey looky there, on the right of this thread.. an add for a $2.99 Wendys Delux Value Meal.. there's your food [img]/ubbthreads/images/graemlins/grin.gif[/img]
mbalbritton is offline
post #5 of (permalink) Old 01-05-2007, 12:44 PM Thread Starter
Journeyman
[ QUOTE ]
Disease free is always nice on a family trip. According to my wife, we're leaving the morning of Saturday 13th and arriving in Atlanta on th evening of the 14th. I am a bit skeptical as to her expectations. She'll have the three year old in the cherokee, and I'll be trying to haul a** to catch up.
Mick
unclmick is offline
post #6 of (permalink) Old 01-05-2007, 12:53 PM Thread Starter
Journeyman
[ QUOTE ]
IF the hole he drilled in the shank is centered... use a larger bit to remove *most* of the bolt (leave the threads intact) "
I tried that but it seems that the remains have been pushed into the threads.
[ QUOTE ]
1) If I pooch this, would I then move to a bigger bolt?
2) If I do this correctly, would you recommend changing form torx bolts to a different head? I saw a number of other postings about it on jeep sites.
[ QUOTE ]
I haven't even see the house yet. Long story. We're renting for the first year until we get our bearings. I beleive it is in Atlanta in a neigborhood called Tucker(?).
At this point now I'm just crossing my fingers and gritting my teeth.
Mick
unclmick is offline
post #7 of (permalink) Old 01-05-2007, 12:57 PM
Just what bolt hole are we talking about on the door? Some bolt's will go into a crash bar. Some will go into metal that's on a flange that's spot welded onto the frame. If you do have to oversize the hole, it can be a problem.
You can fix it, but it takes enlarging the hole and possibly ruining the door skin. That's my worry.
Sometimes you can weld the hole a little, and get something for the new tap to cut threads into. Sometimes you can weld a nut behind the flange/bar and use it as an anchor. It all depends on where the hole is located that you're trying to tap.
post #8 of (permalink) Old 01-06-2007, 11:34 PM Thread Starter
Journeyman
Hey Leve,
I am working on the floating piece whithin the door behind where the hinge attaches. I am sure it has a name, but I don't know it and don't have the time to verify it.
Also when I finish this what are your thoughts on the switch from torx heads? What is your opinion of the most reliable shape for flat surface bolts?
Thanks,
Mick
unclmick is offline
post #9 of (permalink) Old 01-07-2007, 10:46 AM
Caver Dave's Avatar
I used to live in Tucker! 2 sets of inlaws still there (Lawrenceville/Lilburn), so maybe we can hookup during an upcoming trip?
I'd go with the same style bolt in an allen head... *if* a regular hex head won't clear...
post #10 of (permalink) Old 01-08-2007, 02:43 PM
You can see from the picture that the hinge plates on the door do float... somewhat. Like the tub mounts they're in a capture box. The box is spot welded to the side of the door frame.
If you were to remove those spot welds, the box would drop and you could retrieve the plate and make all the repairs you needed. Then simply spot weld the plate back in place when you're done.
That's the cleanest way to do the repair.
As for the torx bolts? That's a good question. I just used grade 5 bolts when I replaced my hinge torx bolt. I did put a washer behind them, but nothing fancy like conical washers that would nestle down into the 3/8" recess of the hinge.
