Oil filler blow back - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-03-2006, 09:38 PM Thread Starter
MarineJeeper's Avatar
I have a problem with my 304, at idle it has a bit of oil vapor coming out of the breather cap. at about 2K RPMs it is as if the engine is on fire. The intake manifold is soaked in oil.
I replaced the PCV valve today and that didnt help.
It is running a little rich but its not that bad.
Any sugestions why this is happening?
MarineJeeper is offline
post #2 of (permalink) Old 12-03-2006, 10:05 PM
Re: Oil filler blow back
It sounds like blowby. When cylinder rings on a motor are worn then excessive amounts of combustion gases (all engines have a small amount of gas that gets past the rings) escape the combustion chambers, past the rings, into the crankcase. The PCV system is designed to neutralize any pressure in the crankcase, and circulate filtered air through the crankcase, so combustion gases don't build up. If the Engine is old, and the rings are bad, or if the PCV system is not functioning correctly, then you can get excessive blowby out of oil filler caps, or any other openings in the engine.
Kevin86 is offline
post #3 of (permalink) Old 12-03-2006, 10:14 PM Thread Starter
Any way of checking rings other than pulling it all apart? would the cylinder presure be lower in a cylinder with bad rings?
post #4 of (permalink) Old 12-03-2006, 11:50 PM
You can do a Leak Down Test. It's about the best indicator test you can do without tear down.
post #5 of (permalink) Old 12-04-2006, 12:22 AM
Raduckal's Avatar
For a few bucks try Restore . It worked great for me on two worn 258s. Of course, if you have a cracked ring or worse it will not help.
Raduckal is offline
post #6 of (permalink) Old 12-04-2006, 01:31 AM
Check the PCV valve. But if you are getting tons of vapor at idle or clouds at 2000 RPM (no load), especially if the engine is still cold, than I would suspect a hole or crack in a piston. As LEVE said do a compression test to tell for sure.
bandhmo2 is offline
post #7 of (permalink) Old 12-04-2006, 05:12 AM
jeepgod's Avatar
another little test is to check the compression of each cylinder.. they should all be in the same range.. if you have cylinders with low compression.. squirt in some oil.. then check the compression again.. if it rises.. then the rings in that cylinder are worn... if it doesnt.. then you have more serious problems..
jeepgod is offline
post #8 of (permalink) Old 12-04-2006, 12:18 PM
Official Historian
WILL's Avatar
Make sure you have vacuum to the PCV valve. It sounds strange but I had that problem with my 78 dodge. The carb had so much carbon in the pcv port, there was no vacuum. I hand turned a drill bit to remove the carbon and it worked again.
WILL is offline
post #9 of (permalink) Old 12-04-2006, 04:24 PM
Caver Dave's Avatar
[ QUOTE ]
Ditto that! My vac port (on the adapter under the 2100) was caked/clogged/crusted to the point I had to use a cordless drill to spin the bit! [img]/ubbthreads/images/graemlins/blush.gif[/img]
Caver Dave is offline
post #10 of (permalink) Old 12-04-2006, 06:09 PM
Aaron871's Avatar
[ QUOTE ]
That's normal, just keep driving it..........
Aaron871 is offline
