4.0 Into 95 2.5 Wrangler Questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-03-2006, 07:32 PM
KYSCJ7
I have a 95 wrangler with a 2.5L and 5 speed. I've been thinking about swaping in a 4.0L. I Have a donor vehical but its a 87 comanchie 2wd with an auto. Is there anything I can use from this? And what else will I need to do the swap? IE; drive shaft(s),tranny,mounts,T-case,skid plate,harness,ECU/PCM? Any Info and opinion on On this Swap Would Be greatly appreciated.
Thanks
Kyle
post #2 of (permalink) Old 10-04-2006, 08:42 PM
KYSCJ7
Re: 4.0 Into 95 2.5 Wrangler Questions
Anyone???
post #3 of (permalink) Old 10-04-2006, 09:13 PM
The biggest problem is putting an older engine in a newer vehicle....not sure about OH, but in CA and many other states, you can't go backwards, just forwards.
I would look for a newer fuel injected V6 or V8....about the same amount of effort as the 4.0.
post #4 of (permalink) Old 10-04-2006, 09:15 PM
My opinion? I'd rather have a '95 2.5L than a '87 4.0L.
jeepete is offline
post #5 of (permalink) Old 10-05-2006, 10:51 AM
westville's Avatar
Kyle- for what it worth, putting in 4.0 isn't worth the effort. If you really, really, really want a 4.0 in a 95 YJ, I would suggest looking for one with it already in it.
westville is offline
post #6 of (permalink) Old 10-06-2006, 05:20 PM
KYSCJ7
UPDATE.
I've got a line on a 93 wrangler 5speed 4.0 wcrecked. The drivetrain is guarenteed good condition I can get the whole jeep for 450. Is That worth it? And what all needs changed.
post #7 of (permalink) Old 10-06-2006, 10:01 PM
Do you plan to rebuild the donor motor? If not and you canít do a compression check, check the air cleaner (if itís still there.) If there is any oil in the box or on the filter you have ring blow by. You may still get some more miles out of the motor but the oil mess will only get worse until you will have to give up and rebuild.
Kriss
Saddle Tramp is offline
post #8 of (permalink) Old 10-07-2006, 02:05 PM
$450 sounds like a great price....assuming the drivetrain is intact....accidents have a tendancy to crack cases....
Just remember....the only savings in effort and money by going with the 4.0 will be the transfer case adapter.....otherwise, 4.0, V6, V8...all the same work......and it's a lot of work....not for the average weekend 'doing it for the first time' mechanic. My SBC swap took 2 years.....(ok, I did a frame up restore as well).......
post #9 of (permalink) Old 10-08-2006, 08:14 PM
KYSCJ7
Well since I don't think the 2.5L is going to cut it with big tires and lift, and I dont want a gas hog I think the 4.0 is my best bet. I figure I'll have a day or to into pulling the 2 motors and a day or two into getting parts and another day or to into the swap. So sometime in the next 2 weeks I'll have the swap done. I'll keep you guys posted and post pics. And if anyone has any more info on the swap please post it.
Kyle
