replacing inner & outer axle seals on Model 20 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-01-2006, 01:03 PM
msamuels
Hello All,
I recently purchased an '82 Jeep Scrambler, 258 T5
I have gear fluid leaking out of the axle seals into the hub/drum brake area.
Can anybody please provide guidance (beyond Chiltons) on how to replace the inner and outer seals on the axle?
Much Appreciation!!!!
Steps?
Special tools besides hub puller?
I would like to do more of the maintenance myself...
post #2 of (permalink) Old 10-01-2006, 08:33 PM
SilentBob2's Avatar
Re: replacing inner & outer axle seals on Model 20
Are they the stock two piece axle shafts or have they been upgraded two the one piece. If they are stock, the outer hub can be a buger to get off! If you are going to do any wheeling, this might be a good time to upgrade with the one piece shafts. The kits come with new bearings and seals. As for special tools other than a puller your going to need a lot of grunt and patience if they are stock axles. A lot of heat might help!!
SilentBob2 is offline
post #3 of (permalink) Old 10-01-2006, 10:04 PM
Inners are simply pressed into the axle tubes and keep the diff lube from mixing with the bearing grease. You can easily yank them out with a slide hammer and hook end, then tap in new ones with a tube of the right diameter. All this is after you have pulled the axles from tube.
On stock 2 piece axles, the outer seal is trapped between the hub and the bearing. You have to remove the hub from the tapered splined axle. Its on very tight, and has to be to survive. You typically use a heavy duty puller to remove it. Often after its been removed and replaced, you spin a hub and the axle is junk. Either the splines are comprimised or the nut isnt tight enough or both. Thus the benefit of replacing them with an aftermarket one piece axle or a whole 'nother axle like a Dana 44. Outer seal is still trapped between the bearing the the hub, but you put it on before installing the bearing and pressed on retainer ring.
You could pull the axles yourself and take them into a shop and have them do the hard part, removing the bearing, hubs, etc.
TiminMb is offline
