t-18 length question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-19-2006, 12:57 PM Thread Starter
i have a t18 from a 6 cyl j10, will that one inch spacer make it too long to use in my cj5 with a 92" wheelbase? The rear axle is apprximately 5 inches rearward of stock.
Happy_Hooker is offline
post #2 of (permalink) Old 09-19-2006, 01:31 PM
Re: t-18 length question
The answer lies in the length the rear driveshaft will be. Can you figure that out?
Jim_Lou is offline
post #3 of (permalink) Old 09-19-2006, 02:41 PM
GoldToyBox's Avatar
Location: Selma,CA in the middle of the vineyards, Central California
Assume you mean the 1" adapter on the rear? It's for mating up to your Transfer Case (Dana 20) If your going with something else like a Dana 300, your going to need a different adapter. It's also for the mounting to the cross member.
Your not giving us much to go on here, you ask about length being too long???? The T-18 is one of the shortest trannys out there? Like Lou said, just measure up. Anytime you change the drive train you'll have to resize your drivelines.
If I remember right the J-10 T-18 have the long input shaft & the bigger bellhousing? You can save some space with the short shaft & smaller bellhousing.
If you just want to know if a T-18 will fit in a CJ-5 .... yea it does, seen lots of them .... with some very short rear drive shafts.
Rockin On
GoldToyBox is offline
post #4 of (permalink) Old 09-19-2006, 02:53 PM Thread Starter
the particular transmission that i have has a 1 inch adapter between the trans, and bellhousing, where most of the j-truck ones have a 6 inch or so adapter. The rear driveshaft should be roughly 20 inches long.
post #5 of (permalink) Old 09-19-2006, 03:29 PM
What you also need to look out fore is how far it will push the shifter back.
Measure from the front of the bellhousing on the T-18 to the front of your tranny. and your current transmission and see how much differance there is. to decide if your shifter will be pushed back too far.
Advanced adapter catalog should be able to give you most of the information you are looking for.And if you call them and explain your situation, they may be able to help alot more.
unhumen is offline
post #6 of (permalink) Old 09-19-2006, 04:09 PM
GoldToyBox's Avatar
[ QUOTE ]
Ok sounds like you have a non Jeep bell housing?
J-10 with a 6 inch adapter????? Huh???
You sure you have a T-18?? Only available '77-'79 with 6 cylinder motors, '70-'83 with v-8's.
What motor are you mating this up too?
post #7 of (permalink) Old 09-19-2006, 04:42 PM
Jeep used the T-18 in FSJ's from sometime in the 60's or early 70's to the 80's. I thought all the early ones had a long adaptor between the transmission and belhousing, some thing like 6 of 8". Also check the length of the input shaft as they may have used a shorter adaptor and a longer Bellhousing. Also make sure you do not have a T98 as these look simmilar to T-18's and have simmilar strength but use shorter lived bearings/bushings.
bandhmo2 is offline
post #8 of (permalink) Old 09-19-2006, 05:13 PM Thread Starter
It is going behind a 360, and was originally behind a 258 in a 79 j10. The bellhousing looks just like the one that was on my t150.
post #9 of (permalink) Old 09-24-2006, 05:51 PM
Official Historian
WILL's Avatar
[ QUOTE ]
My rear driveshaft is 17-1/2" long.
WILL is offline
post #10 of (permalink) Old 09-24-2006, 05:56 PM
jeepgod's Avatar
dang.. i thought all the fullsize jeeps had that 6" adapter... mmm.. i would think that the T18 was not stock in that truck you pulled it from.. and the 1" spacer is used with the T150 bellhousing.. another giveaway that the tranny wasn't stock in that truck.. will it work in your cj5.. yes.. sure will.. you are lucky with that short input...
jeepgod is offline
