What tranny and Transfer to use? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-16-2006, 07:54 PM Thread Starter
I have never posted on this site before but I do follow the posts and I do frequent the AJC Board. I am hopeing someone here can help me.
I have a 46' cj2a with a Ford 302 motor and original 3 speed trany and transfer case. The original axles are also being used, passenger side diffs.
My problem is, the transmision will not hold up to the 302, I have had to have it rebuilt 3 times in 2 years, the synchros are FUBARD.
My question is, what transmission and tranfercase can I use to replace the existing trans and transfer? I don't have a problem of having to buy any adaptors to make something work.
Stacey
Boo Who is offline
post #2 of (permalink) Old 09-16-2006, 08:01 PM
Re: What tranny and Transfer to use?
I would think a Ford T-18 would be a good choice. Lots of folks put them in their CJ's with Dana 300 cases. Adapters are readily available.
jeepete is offline
post #3 of (permalink) Old 09-16-2006, 11:33 PM Thread Starter
Do you know what Fords have the T 18 in them?
Boo Who is offline
post #4 of (permalink) Old 09-16-2006, 11:39 PM
Synchros won't go bad because the transmission is passing too much power. They go bad because of improper installation or improper use, which is what I suspect.
That transmission doesn't want to be shifted like a sports car transmission. It's a small truck transmission, from an era when synchro transmissions were something of a novelty, and any help from the synchro was appreciated. You have to take your time shifting; let the synchro do its job. A shift to second or third ahould take about three seconds.
If you're looking for something that can be shifted quickly, I can't tell you what to put in, but I can say that you won't be happy with a T18; it's VERY trucky.
Jim_Lou is offline
post #5 of (permalink) Old 09-16-2006, 11:57 PM
Only Ford I'm sure of with the T-18 is a '69 1 ton Pickup my cousin has. I know it was used in other Ford trucks but what years and models I can't say. There is a Jeep version but it doesn't have the granny low gear ratio I would expect a Ford would be eaiser to mate to a 302.
Check out this LINK.
here is a excerpt.
[ QUOTE ]
The T18 is a reknown, heavy-duty truck transmission designed for and used in ˝, 3/4 and 1+ ton trucks. The T18 was made by Borg-Warner Gear from 1966 to 1990. They are found in Ford, Jeep and IH trucks. The T18 is the improved successor to the T98.
Read about other transmissions in their knowledge base.
Novak is a good place to get adapters also.
jeepete is offline
post #6 of (permalink) Old 09-17-2006, 01:13 AM
Randyzzz's Avatar
How about a T176? It's fairly heavy duty, shifts alot smoother than a T18, and is a Ford product. It ain't no T18, for sure, but it is a good compromise.
Randyzzz is offline
post #7 of (permalink) Old 09-17-2006, 06:08 AM
[ QUOTE ]
It had the 6.32 first gear, I think for the three years of '76 to '79.
Jim_Lou is offline
post #8 of (permalink) Old 09-17-2006, 02:13 PM
First, every one here seems to be missing something very important. Which ever transmission is used it needs to be short and connect to a transfer case with offset rear output. That narrows the transfer case choses to the fallowing: NP200, Dana 18, and Quadratrac. Of these the NP200 is a very heavy truck case, so not a good chose. THe Quadratrac is okay but is a full time case and was only used behind Auto tranys, so that may not be wanted.
So assuming you still want a part time case that leaves the Dana 18. So the real Question is what transmission is short, strong, and will bolt with a little work to a Ford Bell Housing and bolt with little work to a Dana 18. My thoughts here would be T150, T15, Jeep or international T18 or T19 (in wide or narrow ratio). All of these came in front of Dana 20 Tcases so they will all bolt to a large (4") hole Dana 18, infact they use the same case.
Parhapes a Ford car transmission should also be looked at, as I seem to remember hearing the 3.03 used to be a popular swap into flat fenders.
Do you need/Want a grany gear? How importent is fast shifting? What are you planing to spend? How importent is stock appearance?
bandhmo2 is offline
post #9 of (permalink) Old 09-20-2006, 08:11 PM
SilentBob2's Avatar
I might be wrong but I think some of the late 80's ford mustangs used a T-5 as well as some S-10 chevy trucks. I think the S-10 versions had wider gears for more streangth. Go to Novak adapters and check out the info on tranny's. They have the lengths and weights and what model to find them in. Oh and by the way just don't use a jeep T-5 unless you want the same problem.
SilentBob2 is offline
post #10 of (permalink) Old 09-22-2006, 12:08 PM Thread Starter
[ QUOTE ]
What I am hearing is that my tranny is not inferior, it is the driver, I can accept that. My brother has (borrowed) this jeep for the last 18 months, I keep telling him to take it easy on it.
I think what I am going to do is take my jeep back from my brother, then have a different transmission shop rebuild what I have.
Thanks for all the advice.
Stacey
Boo Who is offline
