Jeep Maintenence - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-16-2006, 11:18 AM Thread Starter
Jeep Maintenence
(04 TJ 31x10.50's Minimal offroad no rock crawling)
What do you do to maintain your Jeep on a month to month basis?
It's my daily driver so it is rarely in 4wd. I've read all the manuals and everything and would like you opinions.
How often should you change the diff fluid? Do you just have to keep it full, or should you replace it?
What is the ideal octane gas to use in it? Should I not be putting BP gas in it?
What else should I be checking? (and how do I check it?)
Thanks.
Cleveland TJX is offline
post #2 of (permalink) Old 09-16-2006, 11:19 AM Thread Starter
Re: Jeep Maintenence
Jeep Maintenance, actually. Whatever.
post #3 of (permalink) Old 09-16-2006, 12:07 PM
ecamp55's Avatar
I change the diff fluids at least every year, more if I feel like I have alot of wheeling in mud or water. I buy the cheap gas from wherever.....except I will not use Citgo products. I look at everything I can think of (bolts, nuts, fluid levels, etc.) after every wheeling trip.
ecamp55 is offline
post #4 of (permalink) Old 09-16-2006, 12:45 PM
Water and the stuff it brings with it is your biggest enemy. Any time you get in water hub deep or more you should grease everything that can be greased.
You should also change the transmission, transfer case and differentials. Any oil that comes out milky has taken it water. Either correct where it's entering or continue to change it after every immersion.
Also after every wheeling trip where there's dust in the air you should inspect the air cleaner. The old standard is that you lay down a sheet of newspaper and bang the flat surface of the air filter on it. If any dust can be knocked loose the element should be changed. Another test is to put the filter around a lightbulb. If you can see light through it, it's still good. I think that test is way too permissive.
Those procedures are neither time nor mileage dependent; they need to be done after every wheeling trip. My Jeep gets very little use, so I change oil and filter twice a year, which may only be a few hundred miles of use.
Something I've done since the Jeep was new is to annualy remove the plug wires, clean them with carburetor cleaner, work silicone grease into the places where the boots meet the wires, and then spray them liberally with silicone spray. They lasted more than 28 years, and never let the electricity out.
That's all I can think of that varies from the maintenance you'd do for any car of similar mileage, age and use.
Jim_Lou is offline
post #5 of (permalink) Old 09-16-2006, 01:26 PM
[ QUOTE ]
IMO, unless you go through deep water, just do what the Factory Service Manual recommends and you will be taking far better care of your Jeep than most people.
jeepete is offline
post #6 of (permalink) Old 09-16-2006, 07:29 PM
jeepjunky's Avatar
Ok I agree if you hit deep water (hub deep or deeper) change all of your fluids: tranny, transfer, diffs. I do mine at least 1x year. I finally got tired of pulling diffs and reinstalling them so I put drain plugs in. Easy to do on your own or about $50 to have it done. A shop did tell me that when you drive your jeep or Pickup for that matter your diff and axle get hot, when you get them wet from submesion (water crossings or backing a boat trailer into the water) It causes rapid cooling an will suck water past your seals.
After you go wheeling crawl under the jeep and look for any scrapes and scratches, make sure it all looks good, ALSO WASH OFF ALL THE MUD...STOP THE RUST. LOL have fun.
jeepjunky is offline
post #7 of (permalink) Old 09-17-2006, 10:51 AM
most axle housings are vented, so it should only suck water past your seals if your axle housing vents are not working correctly.
Kevin86 is offline
post #8 of (permalink) Old 09-17-2006, 10:54 AM
[ QUOTE ]
Or if the vent openings are under water!
jeepete is offline
post #9 of (permalink) Old 09-17-2006, 12:29 PM
What Pete and Kevin said. Same for transfer cases and transmissions.
If all is as it should be - seals are good and vents are high - there's no problem. Until you know that, check all fluids after every immersion.
Some automatic transmsmissions are known leakers at the vent, and the T18 leaks around the shift lever. Those problems should be corrected before immersion. Especially the automatics because they can be ruined in minutes if water gets in.
My Jeep has a single, central vent system. I'm wondering if I could pressurize it to a couple of PSI and watch the leakdown rate to determine the integrity of all cases, vents and seals.
Jim_Lou is offline
