No parking lights after paint work? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-08-2006, 10:18 PM Thread Starter
Journeyman
So I did some painting and removed the rear tailights. After reinstall I have no parking lights. My fuse for the parking lights blew and so did the replacement. The brake lights work and so do the turn signals and head lights. Currently I have the fuse removed with no parking lights or instrument cluster lights. I don't think it is a grounding problem because my brake lights and turn signals lights work but I may be wrong. I had some corrosion on the tailights that was grinded off and I have some new SS bolts w/ star washers and regular washers installed. I did alot of work removing herculiner on the inside of the tub and then doing some body paint also. I had no problems previously before the body work and am looking for beginning direction. So, I have no parking or side marker lights, or reverse lights but do have headlights, brake lights and turn signals. Suggestions needed.
RoryBellows is offline
post #2 of (permalink) Old 09-08-2006, 10:56 PM Thread Starter
Journeyman
Re: No parking lights after paint work?
Could my headlight switch be bad? My headlights work and turn signals etc... plus interior lights but no parking lights?
post #3 of (permalink) Old 09-09-2006, 03:41 AM
jeepnut_nh's Avatar
my guess is a bad wire somwhere, if the fuse is blowin on every attemp, you most likely have a bare wire groundin out somwhere, i'd start at the scene of the work and follow back to the source
edit:
oh--oh....or ya mighta had a brain fart on the rewire(unless they are plugs), check your connections as well
jeepnut_nh is offline
post #4 of (permalink) Old 09-11-2006, 10:24 PM Thread Starter
Journeyman
After pulling my rear harness and checking it I found the culprit. Not in the harness but instead inside the rear tai light behind the little flange. At least now I know my rear harness is in pristine shape.
post #5 of (permalink) Old 09-12-2006, 06:42 AM
So what was wrong inside the rear tai light behind the little flange? Bad ground?
Jim_Lou is offline
post #6 of (permalink) Old 09-12-2006, 02:33 PM Thread Starter
Journeyman
Yes. Very small hole in the insualtion.
