need help! 96 XJ wont start - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-04-2006, 01:16 PM Thread Starter
ok, my buddy brad is working on getting my wrecked 96' XJ (inline-6, ax-15) fixed but he cant get it started. he drove the XJ into the bay to remove the bashed frontend (fenders, bumper, lights, grill and hood) and to test fit all of the new body parts back up before paint, well the jeep would not start after doing all of this. he has tested it out and is finding out that the coil is not getting any fire (the motor turns over but wont start).....he swaped in a new 'puter and still nothing happened (he said it could be have been a bad 'puter also)
WHTTRASH is offline
post #2 of (permalink) Old 01-04-2006, 01:21 PM
Re: need help! 96 XJ wont start
He forgot to hook up the ballist resistor over on the left fender well. It should be there right next to the air cleaner....big white resistor with two wires going to it.
post #3 of (permalink) Old 01-04-2006, 01:43 PM Thread Starter
[ QUOTE ]
just called him and he said that it was never unpluged and he checked to see if the wires were on tight so thats a no go?
got any thing else??
WHTTRASH is offline
post #4 of (permalink) Old 01-04-2006, 01:44 PM
Check to see if the AutoShutDown relay is enabled or disabled.
post #5 of (permalink) Old 01-04-2006, 01:46 PM Thread Starter
[ QUOTE ]
where would this be located on the XJ (brad is a body/paint man)
WHTTRASH is offline
post #6 of (permalink) Old 01-04-2006, 02:05 PM
In the PDC. On the passenger side fender... toward the front.
post #7 of (permalink) Old 01-05-2006, 04:42 PM Thread Starter
ok none of this works yet (but thanks for the help guys)........brad hooked up a reprogrammer to the XJ's computer and didnt get a reading at all so we are guessing that the 'puter is bad so here is the next problem........
the 'puter out of my 96' XJ has a parts #56041293, well when we called to some parts stores (NAPA, autozone, advance, o'rileys) they said that they couldnt get that part number (XX293) but the part coming up for a 96' XJ, 4.0 I-6, 5-speed was #56028852 (hell even the dealer could find the XX293 number)
so heres the problem, should i just go by the XX852 computer hopeing that it works cause once you leave the store you dont get a refund on elect. parts from any of the places that i have talked to....so if it doesnt work then iv tossed about $260 in the craper
just to recap, lights, horn, wipers, power loack and windows work, the engine turns over put gets no spark
thanks
the stupid fat guy
WHTTRASH is offline
post #8 of (permalink) Old 01-05-2006, 05:24 PM
Official Curmudgeon
CJ7Taz's Avatar
[ QUOTE ]
... he drove the XJ into the bay to remove the bashed frontend (fenders, bumper, lights, grill and hood) and to test fit all of the new body parts back up before paint, well the jeep would not start after doing all of this.
If you start a pot, can I get missing GROUND?
CJ7Taz is offline
post #9 of (permalink) Old 01-05-2006, 05:32 PM
I find it hard to believe that the computer is dead.
Are you sure the computer is getting power? No blown fuses?
post #10 of (permalink) Old 01-05-2006, 05:53 PM
A shot in the dark, but a good one -
Check the crankshaft position sensor.
It's on the left side, behind the engine, down on the top of the bellhousing. Hard to see - harder even to replace, but do-able from the bottom.
If the engine shifted forward in the accident, it may have broken the connector or wires from the sensor right behind the engine. It could even have bent or damaged the sensor.
Look close, you'll see the wires running down back there and the connector.
Without a crank sensor signal, the computer will act dead.
I think the sensor is about $35, much cheaper than an ECM.
You can check it - disconnect the connector - attach an analog (meter type, not digital) ohmmeter to the wires from the sensor.
Rx10 scale on the ohmmeter
Crank the engine - the ohmmeter will swing wildly as it cranks - if it's OK.
RRich is offline
