MC 2100 insulator /adapter kit - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-29-2005, 05:16 PM Thread Starter
hey guys finally got my mc2100 but im kinda stuck on which adapter to use and if i need the plastic insulator like on the v8 304. any input is appreciated
82CJnLA is offline
post #2 of (permalink) Old 12-29-2005, 05:40 PM
Re: MC 2100 insulator /adapter kit
Summit sells TD Performance Products adapter no. TRD-2086 for $12.75. It comes with 2 gaskets. I replaced the slotted bolts that came in the kit with allen head bolts to make tightening the adapter to the manifold easier. I also used a hardening gasket maker instead of the gasket between the adapter and the manifold (Permatex Form a Gasket 1A). I also used a Ford gasket between the carburetor and the adapter. It is made of black plastic and looks like two gaskets sandwiched together with plastic bushings inside the stud holes. Is this gasket necessary? There is nothing special about it other than that it will seal very well and also provide a lot of heat insulation from the manifold. The hole in the adapter is slightly larger than the jeep manifold. I have thoughts to switch to an aluminum intake manifold from an 84 and blend the manifold to the adapter with a die grinder.
TiminMb is offline
post #3 of (permalink) Old 12-29-2005, 08:40 PM
jdoggmoney's Avatar
The Mr. Gasket adapter already comes with alan head bolts... and ditto on the Ford gasket. [img]/ubbthreads/images/graemlins/smile.gif[/img] I dont recall the Mr G part number, but I think if you tell them its to adapt a holley style two barrel to a rochester, they will come up with the part.
jdoggmoney is offline
post #4 of (permalink) Old 12-30-2005, 01:49 AM Thread Starter
ok i have the part # for the td performance and the mr. gasket. i like the allen bolts with the mr gasket kit so that's what i'll do. but what is this ford gasket? is it a regular paper gasket made especially for the carb or is it the plastic insulator like the one that comes stock on the 304 w/ MC 2100? the one im thinking is about 1/2 inch thick hard plastic. and if i do use this so called insulator would it go on: intake > papergasket > adapter > paper gasket > insulator > carb? thanks for the help so far. hopefully will i'll get it all done this weekend.
82CJnLA is offline
post #5 of (permalink) Old 12-30-2005, 05:20 AM
The insulator isn't so important on the six because of the way the carb mounts off the side of the engine. I wouldn't go out of the way to install one, but it can't hurt.
Jim_Lou is offline
post #6 of (permalink) Old 12-30-2005, 12:20 PM
GoldToyBox's Avatar
Location: Selma,CA in the middle of the vineyards, Central California
Take a good look at the surfaces between the 'insulator' & and the adapter ...... they don't mate up (at least mine didn't) and you will have a huge vacuum leak!
Mine is a 1973 258 I-6, mid 1980 alum intake, summit adapter, Autolite 2100. Runs great without the 'insulator', connected the PVC line to manifold.
Good luck
GoldToyBox is offline
post #7 of (permalink) Old 12-30-2005, 12:35 PM Thread Starter
thanks for the input. i wont even worry about the insulator then. thanks again
82CJnLA is offline
post #8 of (permalink) Old 12-30-2005, 12:42 PM
That phonelic riser was just that... it was on my Bronco II and my daughters Ford LDT II. I suspect that since both engines were V-6's it was meant to get the Carb (or CPI) up above the valve covers so that linkages, etc., could be attached. It was less expensive to produce the riser out of phonelic than aluminum.
