CJ Wiring - Park/Neut Wiring...Misc
I'm down to the nitty gritty on my wiring...94 SBC TBI into my 84 CJ.
I'm trying to avoid running new wires though the firewall...I think I have enough spare wires in the fuse block....If I can identify a couple.....(wouldn't be an issue if it hadn't been at least 8 months since I initially pulled the harness out of the jeep....I forgot to mark the wires). It also does not help that the Chilton manual I'm using is hard as helll to follow...much less read...
Red and Brown wire coming off the outside of the fuse block. Right side of the block as viewed from the front. Any ideas?
My CJ 'used' to be manual....all gone now. Hence, I need to wire the ignition through the Park/Neutral safety switch. Once again, the manual is not real clear on existing wiring. I'm pretty sure that the wiring on the inside is the same for both Manuals and Auto's.
Any chance any of you (Jim???) have a more accurate copy?
When I'm all done, I'll post exact details on the wiring for the next guy.
