need help please! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-17-2005, 07:11 PM Thread Starter
need help please!
Finally got my donor engine all wired up. It turns over great but no spark. Have tried checking all the wiring to make sure i have the necessary plugs hook up, have changed the coil, and have taken another cps sensor(other than my hesco)and hooked it up. Still nothing. I am out of ideas. Please help.
81cj7 with a '95 donor engine and a '91 cherokee harness: (engine,dash, and rear lights) [img]/ubbthreads/images/graemlins/wall.gif[/img]
dsquare is offline
post #2 of (permalink) Old 09-17-2005, 07:16 PM
Re: need help please!
Does the fuel pump run in RUN and START mode?
post #3 of (permalink) Old 09-17-2005, 07:23 PM
babypoo's Avatar
Location: Milwaukee(which is algonquin for the good land)WI U.S.A
Pick Up Coil?
babypoo is offline
post #4 of (permalink) Old 09-17-2005, 08:10 PM Thread Starter
leve, the fuel pump does come on when you put the key in start position.
babypoo, i have switched out the coil as well. it doesn't seem that i am getting power to the coil though
dsquare is offline
post #5 of (permalink) Old 09-17-2005, 08:22 PM
Not in RUN, but in START... if the CPS isn't being recognized by the ECM you won't get fuel pressure or spark on START. Measure the voltage on the coil to see if the ASD is not enabling the circuits.
One reason to fill out your profile is so that kind people can send you stuff you may need, like a diagnostic chart from a 4.0L engine.... in PDF format. But you'd never receive it because you didn't include an Email in your profile!
[img]/ubbthreads/images/graemlins/violin.gif[/img]
post #6 of (permalink) Old 09-17-2005, 09:08 PM
ecamp55's Avatar
Not the coil, the pick up coil. It's in the distributor, under the base plate....I think
ecamp55 is offline
post #7 of (permalink) Old 09-18-2005, 11:11 AM
Official Historian
WILL's Avatar
If it has a CPS, I don't think it has a pickup coil in the distributor.
WILL is offline
post #8 of (permalink) Old 09-18-2005, 11:15 AM
babypoo's Avatar
My 97 has both.
babypoo is offline
post #9 of (permalink) Old 09-18-2005, 02:31 PM
The one on the bellhousing is the Crankshaft sensor and the one in the dist is the Cam sensor. At least that's what my 87 had.
Keith
Junkfood is offline
post #10 of (permalink) Old 09-18-2005, 10:17 PM Thread Starter
!!Update!!
Ok here is what I have done so far. Have changed coil, distributor, all relays, dash is hooked up with same model as wiring harness, fuel pump kicks on and off, ecm is getting power, turns over, and everything that is needed to start is hooked up. Does anyone know of anything, small or big that I have overlooked or possibly need to check?
dsquare is offline
