oil leak/burn - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-17-2005, 03:27 PM Thread Starter
oil leak/burn
Hi there
At what point do you become concerned about the amount of oil leaking/burning?
Like, a quart for every
3000 miles?
1000 miles?
every month?
each 1 hour trip?
every block?
This is a CJ if that makes a difference...
Thanks
Patrick
OIIIIIIIO is offline
post #2 of (permalink) Old 09-17-2005, 04:44 PM
Re: oil leak/burn
when you have a fire,,,cant afford the oil, or the wife complains about the driveway stains....
Heck, some new cars will burn a quart in 1500 miles and the factory says that is OK.
tincan is offline
post #3 of (permalink) Old 09-17-2005, 11:41 PM
MarineOpLaw's Avatar
Re: oil leak/burn
[ QUOTE ]
[...]At what point do you become concerned about the amount of oil leaking/burning? [...]
"Concern" about oil burning/leaking/loss in a CJ?
Given the commonality of this occurence, I'd be more concerned if it didn't burn/leak/use oil. [img]/ubbthreads/images/graemlins/wall.gif[/img]
BTW, above is not limited to CJ's... common in ALL Jeeps that I've ever owned.
MarineOpLaw is offline
post #4 of (permalink) Old 09-18-2005, 08:26 AM
Re: oil leak/burn
Leaks: Depends on the ratio of puddle size to difficulty of repair.
Burning: Pretty much the same as for leaks, except you want to pay attention if the rate changes noticibly.
Jim_Lou is offline
post #5 of (permalink) Old 09-18-2005, 10:49 AM
Re: oil leak/burn
Is the problem a leak, or burning of oil. Leaks are something you can fix, and usually it's not that hard or expensive... a little sealant - a gasket - thinking - and time and it's gone!
On the other hand, I don't like oil burning... that's indicative of engine problems... so that gets my attention! If that engine's burning a quart and a half between oil changes (I do a LOF every 2,000 miles) I get paranoid...
