Rattling/Crackling kinda noise - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-16-2005, 12:15 PM Thread Starter
JeepnGreg's Avatar
i have this on my toyota, and my CJ used to do the same thing....
doesnt happen when its warm out, only when its cold/cool
makes a crackling/rattling..........sounds just likr someone shaking a can of spray paint, reallllllllly fast
only under load, when the air is cold, and the engine is cold
goes away in warm weather, goes away when the engine warms up, idles and revs fine in neutral
any ideas? no trouble codes
JeepnGreg is offline
post #2 of (permalink) Old 09-16-2005, 12:23 PM
Re: Rattling/Crackling kinda noise
Does the noise increase/decrease with engine speed?
Is the engine RPM equal to or less than the noise?
post #3 of (permalink) Old 09-16-2005, 12:32 PM
Sounds a lot like 'pinging' (pre-ignition).
If this is on your 97 with FI, then you could have a bad knock sensor.
post #4 of (permalink) Old 09-16-2005, 01:19 PM Thread Starter
JeepnGreg's Avatar
this is on my toyota actualyl..shoulda labeled it OT....
Larry, I'll check on the engine speed thing once i can,
till then any other ideas are welcome
post #5 of (permalink) Old 09-16-2005, 05:59 PM
OlllllllOCJ's Avatar
Sometimes a cat or muffler will make some pretty strange sounds when warming up or cooling off.
Just a thought.
[img]/ubbthreads/images/graemlins/40BEER.gif[/img]
Dale
OlllllllOCJ is offline
post #6 of (permalink) Old 09-16-2005, 07:53 PM Thread Starter
JeepnGreg's Avatar
sound like its comng from the engine compartment....i'll check where the cat is located, might be that *shrug*
as for RPMs it does seem related to RPM, disappears as i rev higher though,
so, Cold Engine, Cold Air, under load, lower RPMs, disappears higher up
any other idea that can be readily checked out.....?
thanks!
post #7 of (permalink) Old 09-16-2005, 08:06 PM
Look at the pulleys, the belts, alternator and water pump.
post #8 of (permalink) Old 09-16-2005, 11:34 PM
mach2_nh's Avatar
Yup.. Sounds like pining to me to...
My truck did the same thing just about all the time. I had the timeing so far back the thing had no power. After a new timeing chain it was %100
mach2_nh is offline
post #9 of (permalink) Old 09-17-2005, 01:28 AM
minesbroken's Avatar
Check your flywheel or flexplate. It could have a crack in it. Although its probably one of the things that Leve suggests, when I had a crack in my flexplate it made a similar noise to what your describing.
minesbroken is offline
