Weird coolent leak - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-13-2005, 07:23 PM Thread Starter
OFFroadMUDpunk's Avatar
Weird coolent leak
My jeep started leaking coolent from the bellhousing i check around the head no leaks checked around the intake and the heater hoses no leaks i cant seem to find any thing but a puddle its not big about the size of a half doller the only thing i can come up with is a freeze plug in the back of the block cracked or is just leaking a little its not poring out its just a feew drips any one have any ideas
OFFroadMUDpunk is offline
post #2 of (permalink) Old 09-13-2005, 08:10 PM
Re: Weird coolent leak
There is a core plug in the back of the head. Could that be where the leak is coming from? I don't think there's one in the block back there, but it's been a long time since I've been in there.
Jim_Lou is offline
post #3 of (permalink) Old 09-13-2005, 08:14 PM
pressure test it and you will find it.
BurnedBronco is offline
post #4 of (permalink) Old 09-13-2005, 11:17 PM Thread Starter
i drive the jeep so its under pressure There are core plugs in the back of the block when i put the engine in 4 months ago the core plugs where not rusted or any thing they looked new but im still thinking my leak is coming from there there the head is not leaking checked that like 50time to make sure
post #5 of (permalink) Old 09-13-2005, 11:20 PM
Get a mechanic stethoscope and listen back at the back of the head to see if you can hear the pressure release after the engine's shut off...
post #6 of (permalink) Old 09-13-2005, 11:42 PM Thread Starter
well i can pull that one off i have one of them
post #7 of (permalink) Old 09-13-2005, 11:53 PM
mach2_nh's Avatar
My poor old motor.. [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/codger.gif[/img]
mach2_nh is offline
post #8 of (permalink) Old 09-13-2005, 11:57 PM
Fill it up, throw about 15 psi at the radiator cap and you will find any leaks.
The 'Water' (anti-freeze mix) in the top of the block and in the heads often turn to steam when the engine is shut off and the water pump stops turning.
The 'Coolant' heat soaks, and can turn to steam.
Tape a piece of toilet paper under and/or over your core plugs.
Then run the engine until you reach operating temp.
This will tell you if it's one of the core plugs leaking, or something more sinister...
Junk Yard Genius is offline
post #9 of (permalink) Old 09-14-2005, 06:38 PM Thread Starter
to do that i would hafto drop the tranny and then out it back that is a pain
