Re: Project SBC - Good Weekend
The blue line is the ARB air line.
Yes, I bent the 3/8's stainless steel lines myself...with a little help from "grunt".....the one for the return up by the TBI was a real bit*h.
Both the fuel and return are 3/8 stainless. The return can be smaller but I already had the 3/8. At $5/ft, you don't want t waste it....
Cross brace? If there should be one, I would like to see a pick of what it looks like.
Not a ground stap...that is the wiring harness for the engine...most of it is going throug that hole just to the right of the battery tray. I'm re-using the original hole and computer bracket.
With luck I will crank it over (or at least try) by next week some time.
