MC Pushrod - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-28-2005, 10:11 PM Thread Starter
Apprentice
csc_wyo's Avatar
MC Pushrod
Long explanation to a quick answer...
I just picked up a brake booster w/ MC and proportioning valve from a guy here in CO. Trying to cut corners, I ended up at a dead end...I think. The brake line ports on the MC that came w/ the brake booster were on the engine side of the MC. My existing MC has the ports on the fender side. In order to save time bleeding the brake lines after the new booster/MC installation and switching over the brake lines, I thought I'd just attach my existing MC to the booster. Wrong. The existing MC pushrod extends through the firewall and attached to the break mechanism. The MC that came w/ the pushrod doesn't have a pushrod, just a pushrod from the booster.
Question 1A...Is there anyway to remove the pushrod from my existing MC?
Question 1B...Can I remove it w/o getting air into the MC?
Question 2....Can I keep the proportioning valve that's already on my jeep, or do I have to use the one that came with the booster/MC setup?
Like I said, was in a hurry and just trying to cut some corners here.
Thanks...
csc_wyo is offline
post #2 of (permalink) Old 08-29-2005, 07:41 AM
Re: MC Pushrod
Every one I've ever messed with could just be pulled out - only held in by the rubber boot.
Yep, no problem there, but you'll have to bleed the system anyway, so it really doesn't matter.
It should be fine as long as you're not switching to rear disks.
Jim_Lou is offline
post #3 of (permalink) Old 08-29-2005, 09:03 AM Thread Starter
Apprentice
csc_wyo's Avatar
Re: MC Pushrod
[ QUOTE ]
There's definitely something holding the pushrod in the cylinder. There must be some kind of holding pin because there's no way in hell I can get that thing out of there.
[ QUOTE ]
Why would I need to bleed the system? I wouldn't be taking apart any of the existing brakelines or the existing MC, just bolting the new booster to the existing MC. Ya got me all confused here...not hard though.
csc_wyo is offline
post #4 of (permalink) Old 08-29-2005, 11:17 AM
Re: MC Pushrod
[ QUOTE ]
Well, obviously I haven't messed with every one. The drawing in my FSM shows nothing at all holding the pushrod into the MC other than the rubber boot. Then a note says that the pushrod and boot are used with non-power brakes only.
The drawing of the MC/booster assembly doesn't show anything specifically holding the pushrod into the MC either, so it's hard to say why you can't get it out. My guess is that there's a snap ring down in there.
[ QUOTE ]
I misunderstood. I thought the MC was off the vehicle. Bleeding probably won't be necessary after all.
Jim_Lou is offline
post #5 of (permalink) Old 08-29-2005, 01:00 PM Thread Starter
Apprentice
csc_wyo's Avatar
Re: MC Pushrod
Tonight I'm going to get western with that damn pushrod! I really don't want to replumb my brake lines and bleed the lines....AGAIN! Oh well...why would/should I expect anything to be too easy.
csc_wyo is offline
post #6 of (permalink) Old 08-29-2005, 04:10 PM
Journeyman
Re: MC Pushrod
Isn't there a significant difference in the Manual MC and Power MC? I just swapped mine out entirely and bled my brakes again with fresh fluid.
scrappy9 is offline
