Re: Bar\'s Leaks
Ditto. DITTO. No. Don't use it! IMHP....there are only one or two automotive additives that work, and that means they are woth the money. The rest are, uhhh, SNAKE OIL. Fix the problem the right way, recored, then keep a 50/50 mix of antifreeze/water in there. Really the only additive I like is a product called Rislone oil additive. An old name. Seems to help older high mileage engines, lifter noise, oil consumption.
