Re: 15 Gallon tank the same as 19 gallon tank??
naw its true...on YJs, i have heard mixed info abotut he TJs, but dont care enough to try to take it all apart on mine
its the inlet part of the tank....the tube extends into the tank down a bit so you cant effetively fill past it.......it can be removed entirely, or cut doen a bit to increas capacity
i bet you could keep Topping it off, but you have to do it sloooowwww so it doesnt splash back, i think the vent is high enough in the tank that it wont capture air and you can keep topping it off till it reaches the max capacity....
give it a try if you got a YJ...
