Re: amc 360 cam problem
Same lobe on the cam both times? Did you try and reuse lifters?
New cam means new lifters, all the time, every time...
No exceptions.
Not even if it only ran 20 minutes...
Break in pattern is a break in pattern, and you MUST use new lifters.
Did you 'Pump Up' lifters before using them?
Some lifters will 'Lock Up' if the Priming isn't done correctly (resulting it taking out a cam lobe or bending push rods).
Check for valve spring coil bind on the lobe that went, if it was the same one twice.
Use a preoiler and check the oil flow to every lifter bore.
Check lifter bore sizes, and oil flow around each lifter.
No oil on a new cam/lifter will take one out in about 20 minutes, when the moly assembly lube is worn off...
Break in should be done with petroleum oil, and switched to synthetic oil later. We have real problems getting things to break in using synthetic oil...
'Reputable' doesn't mean Competent... and everybody can have a brain fart...
