Re: Choose a Lift
We've been over this a million times, but it is worth going over again. A 4" lift on a CJ7 would be perfect for 33s. The alternative is
a 2.5" with a 1" body lift. Reason for this is the 2.5" lifts usually ride a little better, less spring arch. Either way will work. I personally
have a 2.5" lift with the 1" body lift and ConFerr shackles that are 3/8" longer than stock. With the swaybar disconnected and at full
articulation the front tires clear, barely, with 33x12.50 BFG ATs.
Brad (from the 4 Wheeling center of the universe, 4 corners USA)
