258 timing question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-24-2005, 07:12 PM
dublg
258 timing question
Hello,
I am installing a used 258 in my jeep. There was not a distributer with the motor when i purchased it. I am unsure if i have it installed correctly. With the "notch" on the harmonic balancer at 0` which cylinder should the rotor be pointing towards in the distributer. Thanks in advance for your help.
Greg Greene
post #2 of (permalink) Old 05-24-2005, 09:14 PM
OlllllllOCJ's Avatar
Re: 258 timing question
Hi and welcome to the board.
You have an old CJ [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
Here are some old threads on the subject of timing (and related things). There are plenty more if you do your own search.
<u>GM HEI Install</u>
<u>Timing advance</u>
<u>Weber and Vacuum advance with GM HEI</u>
Last but not least an old rant of mine:
<u>Timing and Fuel Delivery, some thoughts... </u>
There's lots more there than you asked for, but most of it is worth looking at.
Again, Welcome
[img]/ubbthreads/images/graemlins/40BEER.gif[/img]
Dale
OlllllllOCJ is offline
post #3 of (permalink) Old 05-27-2005, 04:47 PM
dublg
well actually i have been around for 5 years. my old posts must have disappeared because of non use. i took the old distibuter out of old motor and put it in but it would not fire. messed around with it. flipped it 180` checked firing order, ya-da ya-da. started going back and checking voltages at coil etc. and found the dropping resistor for the ford hi-energy coil conversion i did 4 years ago was broken. must have happened during rewiring and new split loom tubing. a hole the size of a football in side of block lets ALOT of oil out. anyways i replaced resistor put distributer back where it was originaly and the bad-boy fired right up. thanks for your help. attached is picture of old motor. check out the hole at front of the block. number 1 rod, well what's left of it is on my workbench. i drove it home the 5 miles after it threw the rod. i started it up and drove it into the garage to pull it. nobody at work beleived that it would still run so i videotaped it. what a racket!
post #4 of (permalink) Old 05-27-2005, 05:04 PM
May I suggest that you go HERE
