Idling/stalling problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-13-2005, 09:14 PM
i0n
Ok, my 89 yj runs like @$#%&!! right now and i cannot figure it out.When i idle at a like after comin to a complete stop or downshift when tryin to slow down,The idle drops real low or it just flat out stalls on me while im driving...Now ive checked all the vacuum lines,Tap and wiggle tested all wires goin to sensors and to the ECM(since i dont have a scanner to check everything that way),tried cleaning out the carb with carb cleaner/injector cleaner and im at a total loss of what it could be, any ideas?
89 4.2L with BA 10/5 trans [img]/ubbthreads/images/graemlins/wall.gif[/img] [img]/ubbthreads/images/graemlins/wall.gif[/img] [img]/ubbthreads/images/graemlins/wall.gif[/img]
post #2 of (permalink) Old 05-13-2005, 09:31 PM
Re: Idling/stalling problem
your carb probably has clogged idle tubes, do a search on the carter bbd carbuerator, and you will find all the information you need to fix your problem.
Kevin86 is offline
post #3 of (permalink) Old 05-13-2005, 11:03 PM
try these:
Carter Carb Info
Useful Info
Engine Tech
Have you rebuilt the carb at all?
Warthog is offline
post #4 of (permalink) Old 05-13-2005, 11:31 PM
OFFroadMUDpunk's Avatar
i got the same problem but it does not stall the idle just drops really low my carb was rebuilt a year ago
OFFroadMUDpunk is offline
post #5 of (permalink) Old 05-13-2005, 11:35 PM
mudPunk, have you tried adjusting your idle screw. or have you set your idle mixture screws?
Warthog is offline
post #6 of (permalink) Old 05-13-2005, 11:44 PM
i have adjusted them and it will run good for a week or to or when my jeep idles slow or goes off road the problem comes back. i wanna do the nutter bypass and adjust the carb as close to stock as i can but i cant find a good write up on it my carb is all weird i unpluged all the electrical and it ran great but all the adjustment screws for every thing alse is all messed up when i was trying to get it to run right befor i unpluged all the crap right now it runs great except trying to slow and stop.
post #7 of (permalink) Old 05-14-2005, 02:58 AM
You might try the Mexican Tune Up.
Rev it to about 2500, put your hand or a CLEAN rag over the top of the carburetor. Completely choke it off so it dies - hold it there till it stops.
It'll be hard to re-start - flooded - but get it going again.
Repeat one more time.
The vacuum generated by doing that sucks water and dirt out of the tiny passages. It's kinda like blowing your nose hard!
Doesn't always work, but if something is clogged it will. Worth a try, and cheap and easy.
Readjust idle mixture and idle speed screws after that.
RRich is offline
