Re: Engine Swap
This has been discussed about 2-3 times in the past 2 weeks.
What you are wanting to do is very doable...but only if you have moderate mechanical skills. If you have to ask how change plugs or how to fix your front brakes...sell your jeep and go buy a new Liberty.
If the above does NOT apply to you...and you have a full set of tools, engine lift , access to a welder (and know how to use it)..then the following is a brief summary.
First, you need a doner. In your case, going from the 4 to a 6 requires new motor mounts, electrical, drive line changes, exhaust, etc. Just using a jeep 4.0 does not make it a PNP. Which opens up engine options...for the same amount of work, you can put in a V6 or V8.
As for smog laws...CA is the toughest...but as long as the engine is fram the same year or newer, it's ok...in my case, I'm putting in a 5.7L TBI from a 94 Chevy PU...my 84 jeep will end up testing as a 94 PU.
At a min, you want the whole doner vehicle. You will need the engine, tranny (in most cases, most newer model veh have the computer controlling the engine and transmission...it will just make life easier), wiring harness, computer, vacuum lines, canister...and a few misc items from under the dash depending on your choice.
Then depending on what engine you selected, you may need an tranny to xfer case adapter. If you go with a jeep engine, then you will most likely use the new xfer case.....assuming the front drive shaft is output is on the same side as your front axle.
You will need to weld or bolt in new motor mounts.
Your transmission cross plate will need to be moved,
New radiator.
Fuel lines.
Interface your existing wiring to your new wiring.
Exhaust.
Lengthen or shorten driveshafts.
And a ton of other misc items.
Now....fill out your profile before the flame gods get a hold of you....
