Dual Alternators - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-09-2005, 03:25 AM Thread Starter
Dual Alternators
Not that I need to do it, but I was just thinking about dual alternators.
Someone said that they would interfere with one another because they would be trying to compensate for one another..
Technically wouldn't it be the same setup as when you have two trucks hooked together with jumper cables? There aren't any odd side effects when they're hooked together, but maybe it's because its not being driven.
So is there a reason why dual alternators wouldn't work? (assuming stock alternators without modifications?)
Infernozx is offline
post #2 of (permalink) Old 05-09-2005, 06:51 AM
Re: Dual Alternators
If the alternators were trying to feed the same battery at the same time, I think you'd find only one does all the work, while the other one loafs.
Remember, a battery can only accept about a maximum charging current of about 30 amps. More than that will destroy it. And, since a battery has internal resistance, it "self regulates" how much it can absorb anyway. To get more than 30 amps into it, the voltage has to be way up - like 17 volts or more. Both alternators would have voltage regulators in them to prevent them from going that high anyway.
But dual batteries each fed with it's own alternator could be handy for winching or as a back-up.
I mounted a second battery in my Rubi - so I can use a Ready Welder -- now THAT'S been real handy!
RRich is offline
post #3 of (permalink) Old 05-09-2005, 09:13 AM
Official Historian
WILL's Avatar
I bought a high output alternator from www.4alterstart.com 2 weeks ago. It was the 130 amp one. At idle, it will run my electric fan, lights, wipers and heater blower on low and still stay above 12 volts.
WILL is offline
post #4 of (permalink) Old 05-09-2005, 09:19 AM
JeepnGreg's Avatar
Are YJ alternators the same as TJ alternators?
If so i know theres a cheap junk yard swap for a 136amp for TJs out of certain Dakotas and Rams, but you have to change the pulley (they have a 7 groove serpentine, TJs have a 6 groove)
not sure if they are the same...but its a good option if they are
JeepnGreg is offline
post #5 of (permalink) Old 05-09-2005, 12:27 PM Thread Starter
I've got a Buick 90amp sucker on my SBC right now.
As it turns out, the reason my voltage gage takes a dive every time the trucks been running for 20-30 min is a combination of the taurus fan, and some bad grounds somewhere.
The system holds 14volts even when its fully loaded (except the winch) when checked at the battery with a known good multimeter.
I was just pondering dual alternators.
Isn't having the two vehicles tied together with jumper cables identical to dual batteries that are not isolated from one another?
I was just curious about the theory... wasn't really going to put it into practice... besides the other alternator is reserved for an OBW one day. [img]/ubbthreads/images/graemlins/grin.gif[/img]
post #6 of (permalink) Old 05-09-2005, 01:11 PM
Yes, jumpering 2 vehicles together would be about the same.
Most likely one's doing all the charging in that case too.
I wouldn't think it'd be good practice to have both vehicles running at the same time for long tho. There could be some interaction between the 2.
RRich is offline
post #7 of (permalink) Old 05-09-2005, 02:11 PM
[ QUOTE ]
When a battery is really low either alternator by itself might not have enough output to bring the voltage up to the regulator set point. In that case they will both put out as much as they can. That situation is likely to last a very short time however.
All voltage regulators are set about the same, but they aren't exactly the same, even if they're supposed to be. Whichever alternator has the higher set point will do all the work. The other will see that the system voltage is higher, even if only a hundredth of a volt, than its set point and so will shut down.
That won't cause a problem by itself, but the complexity of wiring, belts and mounting won't buy you much either. You will have more output, but you can get that with a bigger alternator. You will have redundancy in case one fails, but the complexity is a poor tradoff IMO. Plus, there's the issue of maximum charging rate.
I have an ammeter in my Jeep with a 56 amp Delco. I almost never see the alternator putting out full capacity. The only time is if the battery is really run down from leaving lights on or something like that, and then it only puts out for a minute or two before it starts backing down.
Jim_Lou is offline
post #8 of (permalink) Old 05-09-2005, 03:07 PM
lomodyj's Avatar
Just because nobody has mentioned it in this thread. You could hook it up and drive down to the bash and we all could see it at the Bash. [img]/ubbthreads/images/graemlins/grin.gif[/img]
lomodyj is offline
post #9 of (permalink) Old 05-09-2005, 03:10 PM Thread Starter
With the way my tranny is slipping now, I'd probably go through $400-$500 in fuel just to get there.
post #10 of (permalink) Old 05-09-2005, 11:28 PM
Official Historian
WILL's Avatar
I didn't swap in a high output alternator for the top end output, I did it for the idle output.
WILL is offline
