258 mech. fuel pump block off plate- which one? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-08-2005, 10:40 PM Thread Starter
So... I went to a speed shop and found two fuel-pump block-off plates. One looks like a diamon and has two bolt holes, the other looks like a rectangle with a pointed end and has four bolt holes. Which do I need for my 258?
Sycho15 is offline
post #2 of (permalink) Old 05-08-2005, 11:31 PM
Official Curmudgeon
CJ7Taz's Avatar
Re: 258 mech. fuel pump block off plate- which one?
You could look at the pump and see how many bolts hold it to the block.
CJ7Taz is offline
post #3 of (permalink) Old 05-08-2005, 11:34 PM
There are two bolts on my 258 pump.
Jim_Lou is offline
post #4 of (permalink) Old 05-08-2005, 11:56 PM
Official Historian
WILL's Avatar
2 bolt diamond.
WILL is offline
post #5 of (permalink) Old 05-12-2005, 07:08 PM
mindbender
I tired finding a blockoff plate and couldn't - so just took a piece of sheet metal and the grinder and made one. Used silicon for a gasket. Have not had a problem in 3 years.
post #6 of (permalink) Old 05-13-2005, 12:39 PM
Journeyman
I've heard it is the same as the Chevy Big Block. I know I've seen the chrom ones at the parts store that look very similar.
bleoh is offline
post #7 of (permalink) Old 05-15-2005, 02:21 PM Thread Starter
Yup- my local Discount Auto had one, and the Automotive Engineering store had three different types to choose from.
Monday I should be picking up the gas-tank straps and installing a '90s F150 rear fuel tank into my J10. I'm going to hook up electric pumps to both tanks and run them on seperate fuel lines, with seperate filters, up to the inline fuel-pressure regulator before the carb. I'm going to take a headlight switch (the push-pull type) and install it in the dash below the current headlight switch. Wire it for OFF-Front-Rear selections and have the pump and corresponding sending unit activated by relay. I should be able to carry a little over 30 gallons of fuel this way, which should help with my trip to Uwharrie during the Memorial Day weekend (26-30). It's ~660 miles each way, and at (gestimated) 15mpg, I'll only have to stop for fuel once along the way.
Sycho15 is offline
post #8 of (permalink) Old 05-16-2005, 01:59 AM
Official Historian
WILL's Avatar
What about the return line?
WILL is offline
post #9 of (permalink) Old 05-16-2005, 10:17 AM Thread Starter
The electrical pumps I'm using say "Prevents vapor-lock, no return line needed". Otherwise, I'd get different filters with return lines and run them back to their respective tanks.
Sycho15 is offline
post #10 of (permalink) Old 05-16-2005, 03:45 PM
Official Historian
WILL's Avatar
I take it you are running a carb still then. That will work.
WILL is offline
