TJ --- CB Power - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-05-2005, 11:01 PM Thread Starter
TJ --- CB Power
Mounted my CB for the bash this evening. Just need to tie my power in. Whats the best place you know of?
KentuckyCrawler is offline
post #2 of (permalink) Old 05-05-2005, 11:19 PM
JeepnGreg's Avatar
Re: TJ --- CB Power
battery directly is best, avoids interference from other electrical systems in heep
i've actually run a few radios (very low power requirement) off my Cig lighter circuit with good results....but thats not always the best method
JeepnGreg is offline
post #3 of (permalink) Old 05-05-2005, 11:27 PM
Rio_Grande's Avatar
Re: TJ --- CB Power
I ran a #6 wire into the cab and put in a fuse block and switch. Everything I run is relayed except the cb, so i can jump power off of that to any of the 5 cab switches I have. I like it because it brings a good bit of power into the jeep and being of heavy guage I can use the power for several Items. I go to the outside fuse block connector one side only has power when the ignition is on and that was the pole I tied into.
Rio_Grande is offline
post #4 of (permalink) Old 05-06-2005, 01:17 AM
Official Historian
WILL's Avatar
Re: TJ --- CB Power
I plugged a wire with a spade connector into the radio port in the fuse block. It is switched with the ignition though.
WILL is offline
post #5 of (permalink) Old 05-06-2005, 01:40 AM
OlllllllOCJ's Avatar
Re: TJ --- CB Power
[ QUOTE ]
I use a crappy old CB that I won't even tell about... and it plugs into the cigarette lighter. Would suggest that you wire it hot even when your Jeep is turned off. Several times folks where trying to yell... but I wasn't powered up. Guess that's one way to ignore everyone.
Just a thought.
[img]/ubbthreads/images/graemlins/40BEER.gif[/img]
Dale
OlllllllOCJ is offline
post #6 of (permalink) Old 05-06-2005, 06:35 AM
Re: TJ --- CB Power
I ran in a fused wire from the battery, and also used to power cig lighter now too.
shawn
80cj is offline
post #7 of (permalink) Old 05-06-2005, 07:27 AM
Re: TJ --- CB Power
Mine is a cigarette lighter plug with an inline fuse, basically because I only have the cb in the jeep when I'm on a trail run, so I can just plug in and go
kerryp is offline
post #8 of (permalink) Old 05-06-2005, 09:25 AM
lomodyj's Avatar
Re: TJ --- CB Power
Speaking of CB's. I have a couple of handhelds and an old box unit mounted on a board with a cig lighter plug and mag mount antenna. Should I bring these to the bash? or does everyone have a CB?
lomodyj is offline
post #9 of (permalink) Old 05-06-2005, 01:32 PM
Re: TJ --- CB Power
[ QUOTE ]
Good lord, Dale I remember that thing. That thing is ancient. [img]/ubbthreads/images/graemlins/neener.gif[/img]
rubiconvict is offline
post #10 of (permalink) Old 05-06-2005, 09:48 PM Thread Starter
Re: TJ --- CB Power
Thanks for all the good ideas. I am going to wire it straight to the battery with fuse protection to reduce the interferance and so I can use it with my ignition off.
