- Jeep-Short Wheelbase
- - Re-Drilling Scout II Dana 44 spindle to 6 holes?
(https://forums.off-road.com/jeep-short-wheelbase/208272-re-drilling-scout-ii-dana-44-spindle-6-holes.html)
I was wondering if anyone has re-drilled the 8 hole Scout II Dana front axle spindle to six holes? I'm wanting to use my already paid for Dana 44 Scout II - spindles, rotors, disc brake calipers / brackets and outer axle shafts on my Dana 44 Cherokee axle which has flat top knuckles. If this is possible, let me know who I should get to do the re-drilling.
dave |
Re: Re-Drilling Scout II Dana 44 spindle to 6 hole
Couldn't Dutchman in Portland do for you? They'd probably weld up the old holes and drill new ones.
http://www.dutchmanms.com/pricesheet.html |
Holy de-ja-vu..
I don't know where it's coming from, but I honestly remember making this post before. http://img17.paintedover.com/uploads..._002_small.jpg bolt the sucker to a 6 bolt caliper bracket, and just drill away. it's not rocket science. |
Thanks Infernozx
A picture is worth a 1000 words. A search feature that could find your old post "priceless" dave |
I think you could just use a CJ dana 30 spindle... but it's been a while since I did this stuff..
Thanks Elusive,
Did you think the CJ Dana 30 brake caliper bracket & caliper would work with the Scout II disc brake rotor & hub assembly? This is assuming I find the early 77/78 (large) CJ Dana 30 brake caliper bracket & caliper. dave |
Yes they will work... outside of the 6 vs 8 hole deal on the bracket & spindle... they're identical. If you check the suppliers, the CJ "big brake" setup uses the same rotor & caliper as the Scout (seems like there was another that used them around the same time... Bronco/F-truck maybe?)
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
