-   -   harmonic balancer on transfer case.... (https://forums.off-road.com/jeep-short-wheelbase/207298-harmonic-balancer-transfer-case.html)
80cj 04-11-2005 01:29 PM
whats the point of the harmonic balancer on the tailshaft of the np231? i think that not all np231's have them. just curious. since w/o that the sye would have been a 3 hour job (who keeps a puller with M6 x 1.0 bolts that are 7 inches long!!!) pain in my butt!!! anyway, just curious why its there.
thanks all
shawn
jeepete 04-11-2005 02:11 PM
Re: harmonic balancer on transfer case....
Is this on your 2000 tj? I never heard of such a thing. With a slip yoke? was it inside the cover or what? I've been researching the 231's just now and I've not seen any balancers mentioned anywhere. Looked at a couple of parts lists and exploded views and haven't seen one yet. There is not one mentioned in the SYE instructions I just read. (I have a kit on the kitchen table) Sorry, I have no answer, just more questions. Could you post a pic? [img]/ubbthreads/images/graemlins/40BEER.gif[/img]
GP'n 04-11-2005 02:54 PM
[ QUOTE ]
Well thats a new one on me too [img]/ubbthreads/images/graemlins/confused.gif[/img].
Yes a picture would be very good [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
80cj 04-11-2005 03:43 PM
the balancer was stock and i removed it when i put the kit on. it was THE major pain of the conversion b/c like i said i needed metric 6x1.0 bolts that were 7 inches long to clear the stock output shaft. (trip to hardware store to buy metric bolts then welding them to the end of 5 inch long 1/4 bolts since they didn't sell any metric longer than about 2 inches) i don't have any pics of the balancer before i pulled it though.
and yes it in on my 00 TJ.
thanks all
shawn
JeepnGreg 04-11-2005 04:26 PM
i would also like to see pics if possible, where was the balancer located? im pretty sure i dont see one on my TJ
odd
80cj 04-12-2005 06:43 AM
i will try to mock it up and take some pics of it. when i get a chance... so no one else has this? wow aren't i the lucky one!
shawn
elusive 04-12-2005 08:50 AM
yup.. my 2000 has it too, but I did the hack and tap SYE and just left it there.
jjh40 04-12-2005 10:54 AM
1 Attachment(s)
It was used for two reasons. It was to dampen a low frequency vibration coming from the T-case. If memory serves correct it is 55hz. It also takes the place of the tin washer in the slinger seal. the one that the flared rubber seal rides against. This damper is also used on some XJ's. It was designed by the Hillsdale Tool division of Eagle Picher Automotive, for New Venture Gear in Syracuse NY. I was the engineer that set-up the production line on this part. Two double spindle cnc lathes, and an assembly press to put the rubber in. Oh yeah, a vertical cnc machining center to drill and tap those dreaded puller holes. They were hard to keep in the right position because they are very close to the rim of the hub. I think I have a part at home, and I'm sure I have prints of it still. FYI, there is a very similar damper on Libertys also. I do not work for that company anymore. I may have a picture of the damper if I do a little digging. I'll post it if I find it.
mach2_nh 04-12-2005 02:54 PM
I dont think the NP231's have them. But the Rubicon has the NVG241OR and that has one. I pulled it off and used a D300 yoke you gain like 3"
RRich 04-12-2005 03:44 PM
Yup, my Rubicon had one too. Didn't need a SYE as the splines are already in the shaft, but when I lifted it I took it off and used a CV shaft.
Hasn't seemed to be detrimental, although it may have a small vibration that it otherwise wouldn't have. Can't really tell.
Great to hear from the original developer! Wouldn't it be nice to hear from other guys that were in on the designs of things? Sure would answer some questions as to "Why did they ---."
