My rear scout dana 44 disk brake write-up - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-13-2005, 09:58 PM Thread Starter
ricochet's Avatar
Well as the title says, here is my conversion I did. Use it in good health.
Disk brake conversion
ricochet is offline
post #2 of (permalink) Old 03-14-2005, 12:04 AM
GoldToyBox's Avatar
Location: Selma,CA in the middle of the vineyards, Central California
Re: My rear scout dana 44 disk brake write-up
Thanks for sharing
[img]images/graemlins/yourock.gif[/img]
GoldToyBox is offline
post #3 of (permalink) Old 03-14-2005, 06:23 AM
My rear disk conversion was very similar, but I used my old CJ front disks and calipers. I didn't weld the caliper brackets on the axle either, I made spacers and used longer bolts on the flange. I ground down my axles the way you did too. I still have to upgrade my booster/MC yet. Other than that, it works fine.
boogercj7 is offline
post #4 of (permalink) Old 03-14-2005, 08:40 AM
For some reason my first post didn't go through. Hope this doesn't double up.
Good write up - thanks.
Question -
Do you have a link or other contact for
A&A bracket part# 049
Thanks,
wbcarver is offline
post #5 of (permalink) Old 03-14-2005, 09:23 AM Thread Starter
ricochet's Avatar
Ask and you shall receive....
http://www.aa-mfg.com/pdshop/shop/item.asp?itemid=7
ricochet is offline
post #6 of (permalink) Old 03-14-2005, 10:03 AM
Great job!
TiminMb is offline
post #7 of (permalink) Old 03-16-2005, 09:19 AM
Mel85CJ's Avatar
Keith.. cool! We just are finishing up that on my jeep for the rear wagoneer AMC 20.. same thing.. used a *slightly* different part from A&A
here are some links to *in-progress* pictures:
http://www.jrtzone.com/kelsjeep/p3110993.jpg
http://www.jrtzone.com/kelsjeep/p3110994.jpg
we are using the caddy calipers with the e-brake, hence the different bracket.
Also, we have 6-bolt rotors... I'm gonna do a writeup also.
One other thing, what are you using for a master cylinder & proportioning valve... we have a waggy m/c (tried to put on a corvette m/c, but it won't fit with the 258 and the howell kit b/c of the air cleaner)... we found the rears to be a bit spoungy and are adding a residual valve ($15 from summit or something like that) b/c we pretty much just had the rear going straight back with the drum brakes b/c it was pretty crappy.
-Mel
Mel85CJ is offline
post #8 of (permalink) Old 03-16-2005, 05:09 PM Thread Starter
ricochet's Avatar
I'm going to be using a 78 mercury marquis 4 wheel disk master cylinder (has to be the one that was connected to a hydroboost) As for proportioning, i'm going to run the front directly to the mc, and use a manual one for the back. I went with the standard chevy caliper but am installing a line lock instead.
ricochet is offline
post #9 of (permalink) Old 03-16-2005, 06:53 PM
general420's Avatar
Not to hijack the thread, but what rotors did you use on the Waggy HD 20? I'm getting mine ready to go under now, and would like to entertain rear disks. I can wait for the rightup if it's forthcoming.
general420 is offline
post #10 of (permalink) Old 03-16-2005, 08:06 PM
GRQster's Avatar
Great write up, I'm in the process of building my Scout 44's right now. This will be very helpful.
Thanks,
GRQster is offline
