Mix & match CJ-YJ Brakes - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-13-2005, 09:44 PM Thread Starter
Journeyman
Did a search and came up with a WHOLE lotta stuff but nothing concerning my situation. I've got a 90 Wrangler tub on my 78 CJ frame. The CJ had manual disc/drum brakes. The YJ had Power disc/drum brakes. I currently have the 90 YJ booster/MC proportioning valve set-up installed. I will be swapping on an Offenhauser 4V intake and am concerned about interference between the brake lines and the carb/intake. My 78 CJ had the brake lines exiting the MC towards the outside the YJ power set-up has the lines exiting towards the inside. Can I use my good CJ MC (from a non power application) with the YJ booster? And if so, what about the proportioning valve? Should I use the CJ or the YJ one? Or another one? tires are 33X12.50's This is an in progress project that I'm not currently driving. I am assuming that I'm better off keeping some sort of power brakes but honestly, my CJ stopped pretty good with non-power brakes but already having all the YJ power stuff makes keeping the power seem like a good idea.
Thanks,
7T8CJ7 is offline
post #2 of (permalink) Old 03-13-2005, 11:32 PM
jeeperjohn's Avatar
Re: Mix & match CJ-YJ Brakes
I believe the 88 YJ had the lines exiting the left side of master cylinder. check the caliper piston and wheel cylinder sizes of the CJ and the YJ. If they are the same my guess would be use the 88 master cylinder and the YJ proportioning valve. The advance Auto Parts website shows the same part number for the brake boosters so use the YJ one.
jeeperjohn is offline
post #3 of (permalink) Old 03-13-2005, 11:56 PM
YJ ones exit out towards the passanger side.
Infernozx is offline
post #4 of (permalink) Old 03-14-2005, 05:28 AM
jeeperjohn's Avatar
They sure do. My bad.
post #5 of (permalink) Old 03-14-2005, 07:53 AM
The YJ's all have the brake lines on the passenger side as stated, now think a little here [img]images/graemlins/grin.gif[/img].
There is no difference in the placement of the master cylinder, carb or motor from the CJ / YJ so other than line placement there should be plenty of room right [img]images/graemlins/grin.gif[/img].
That said the line on the YJ are basicly under the master and they come up the passenger side and have a tight 90* into the master.
here are a few pic.
and another, as you can also see the MC2100 fits nicely with a 9"filter element [img]images/graemlins/grin.gif[/img]
and NO you can't use the non power unit on a power system.
GP'n is offline
post #6 of (permalink) Old 03-15-2005, 08:47 PM Thread Starter
Journeyman
Thanks all (esp GP'n for the photos)
7T8CJ7 is offline
post #7 of (permalink) Old 03-18-2005, 11:17 AM
Keep the YJ valve, could have kept the CJ valve. If you want a master that is a direct mount and goes towards the wheel well let me know and I will look it up.
Vancopbs is offline
post #8 of (permalink) Old 03-21-2005, 08:47 PM Thread Starter
Journeyman
Van,
I still have all the CJ stuff too. Is the CJ better or just acceptable? Yes, I might well be interested in the drivers side exit M/C,
Thanks
7T8CJ7 is offline
