Which Clutch -TPI 350 + T-18? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-08-2005, 11:04 AM Thread Starter
I need some help finding the correct part numbers for the clutch/pressureplate/throwout bearing. I have a tuned port injected 350 from a 1990 firebird. I am attaching it to a t-18 transmission from an older jeep using advanced adapters bellhousings. Has any one done this conversion and has their clutch part numbers laying around? Any advice?
Seth867 is offline
post #2 of (permalink) Old 03-10-2005, 07:47 AM
dave's Avatar
Re: Which Clutch -TPI 350 + T-18?
Generally, GM offered two sizes of clutches. The Camaro / Firebird is usually 10.4". The GM 1/2 ton pickup is usually 11". So I'm thinking the clutch size and friction disc spline count is where the conversion gets tricky. The Ford T-18 is usually 10 spline, while the Camaro / Firebird is usually 26 spline. Let me know what size your flywheel is (153 tooth or 168 tooth), and I should be able to suggest the correct combination of parts. My 80 CJ5 has a Chevy V8, Lakewood bellhousing, 168 tooth flywheel, and 11" clutch.
dave
dave is offline
post #3 of (permalink) Old 03-12-2005, 05:49 PM
jeeperjohn's Avatar
Not trying to be smart, but have you asked advanced adaptors? Don't settle for thier BS answer of "We have a special clutch, bearing etc". Tell them you want an application for the part or a part number. If they refuse to help you, it is a simple matter of looking up disk diameters and splines, pressure plate diameters and mixing and matching. Finding the through out bearing and pilot shaft bearings may be tricky part.
jeeperjohn is offline
