money saved ....tires & lift or axles? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-03-2005, 11:05 AM Thread Starter
kakwajeep's Avatar
This is my first post and I need some advice. Saved money, enough for lift kit, tires and rims OR axles. My thought was 4" suspension lift 2" body lift with 35" tires. Brother says NO, go for Dana 44's first, then the lift and tires. [img]images/graemlins/wall.gif[/img]I don't want a "Pavement Princess" anymore. Jeep is 91 yj renegade. Original owner.
kakwajeep is offline
post #2 of (permalink) Old 03-03-2005, 12:46 PM
MTPockets's Avatar
Re: money saved ....tires & lift or axles?
Go for the suspension lift, no body lift, and smaller (32" or 33") tires. This will give your rear Dana 35 a better chance of surviving. Wheel for a while on this setup. Learn what the Jeep can and can't do. Get a feel for the vehicle. By the time you wear those tires out, you will:
1. Know whether or not you need bigger tires (and axles).
2. Have saved up money for the beefier axles.
MTPockets is offline
post #3 of (permalink) Old 03-03-2005, 12:50 PM
I second that
rubiconvict is offline
post #4 of (permalink) Old 03-03-2005, 01:25 PM
I third that....
A Body lift causes more problems than it solves.....
With 35" Tires, your tranny and diff will not survive....rule of thumb (or rule of Leve, CJTaz, take ur pick), 32-33" tires, 4.10 gears...35" tires, 4.56....hence, with your stock gears, even 31" tires will make your rig struggle...Axles are a good idea...but have a long term plan and figure on doing gears and lockers at the same time to save money.....
Then you have issues with driveline vibration, new shocks...etc.
The reality is...once you get over 31", the cost goes WAY up....you just can't add bigger tires and expect to off road with ease.
But you are off to a good start....your asking questions.....and believe you me....you will get plenty of answers....
Welcome and have fun.....
post #5 of (permalink) Old 03-03-2005, 04:44 PM
Pete88YJ's Avatar
Ah the struggle...
So many points to consider...
If you want 44s, you'll likely be going 5 on 5.5 wheels, so you won't want to buy new wheels now for your existing 5 on 4.5
You will want to regear for the 35s, and you don't really want to spend money on regearing a dana35.
And, you don't 'really' want to run 35s on a dana35, anyway.
So, for our first conclusion .....suspension aside: 35s, wheels, and axles, all sort of go together.
Now, there are other options to going 44s that you may want to look into. The dana 30 front you have will handle 35s (with the larger u-joint halfshafts) but many consider that its limit. Put a Ford 8.8 in the rear, retaining your 5 on 4.5, you'd have disc brakes all around. There 'are' dana44 rear axles for YJs (from comanchees and cherokees) with a 5 on 4.5 pattern, but they are hard to find, and are drum brakes.
So, you could go different ways....
Now, suspensions: a 4" suspension is the limit for your slip yoke, and you may go through u-joints in your rear driveshaft at a higher rate. A SYE, and a CV shaft are in the cards at some point. Because, a 4" lift with a drop-transfer case is ok, but you really lose ground clearance with it, almost defeating the lift.
Someday you will want a SYE and a CV shaft to go along with your lifted suspension.
Options:
1) Do nothing now, put money in bank, save more money to get new axles, 4" lift, regear, wheels, SYE, CV shaft, 35s.
2) Smaller lift now - 2.5"-3.5", 31s on your stock wheels, and have a great time as you learn. Go bigger later.
3) Go 4" suspension now, 32s (probably the outside limit on your stock gears, and won't wheel as well - your crawling ability is more reduced the larger you go.)
I'd go #2.
Good luck
Pete
Pete88YJ is offline
post #6 of (permalink) Old 03-03-2005, 04:49 PM
Buy/fab/install a full roll cage and a winch before you even think about a lift...
post #7 of (permalink) Old 03-03-2005, 04:51 PM
jdoggmoney's Avatar
4 or 6 cylinder? If you have a six cylinder, the added torque and Hp will help with the gearing problems. If you have a four, be very careful, most say gearing is a must past 31" tires. Welcome [img]images/graemlins/grin.gif[/img]
jdoggmoney is offline
post #8 of (permalink) Old 03-03-2005, 04:55 PM
lomodyj's Avatar
[ QUOTE ]
+1 [img]images/graemlins/thumbsup.gif[/img] [img]images/graemlins/applause.gif[/img]
lomodyj is offline
post #9 of (permalink) Old 03-03-2005, 05:54 PM
While it would appear that LEVE and I have certain philosophical differences of opinion, I have to say that Im 100% on board with his suggestion. My own cage is about to get seriously beefed up. I also concur with the "do what you have to to get 31's on it" and enjoy, as you figure out what you want to do with the next pile of money.
Tyrone Corn is offline
post #10 of (permalink) Old 03-03-2005, 07:23 PM Thread Starter
kakwajeep's Avatar
I've been running 30x9.5x15 Goodyear Wrangler GSA's for the last three years as they don't make the 29"s that were originally on her. She's an I6. Any suggestions on a good brand of roll cage? And bolt in or weld? I read about April and I've seen pictures of jeeps been sold for parts on www.jeepstuff.8m.com in Calgary. That alone convinced me, I just didn't have a roll cage this high on my list. I so appreciate the advice and words of wisdom that you all are giving me as the only other person that I know that has a jeep is my brother. [img]images/graemlins/bow.gif[/img]
