Should indexed spark plugs face head or piston?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-24-2005, 11:26 AM Thread Starter
If you side gag and index your plugs which way should the gap face and in your opinion why is your way the best??
I know engines so we are talking best combustion angle.
Thanks
Doug
MudLake is offline
post #2 of (permalink) Old 01-24-2005, 11:55 AM
Re: Should indexed spark plugs face head or piston??
The gap Towards the intake valve. I think the reason to index your plugs is to be sure the spark gap isn't shielded to the flow of the mixture coming into the cylinder.
I havn't heard of "side gapping" a plug but maybe it was called something else in my day.
OK. Found it:
Interesting idea. Must be a well kept secret as all the ignition books I've read has never mentioned it.
http://performanceunlimited.com/docu...degapping.html
John_Strenk is offline
post #3 of (permalink) Old 01-24-2005, 12:18 PM
Carpal \'Tunnel
knifeboy2's Avatar
I've heard of it, and never put much thought into it, as I can't imagine it makes a noticable difference on my tired 304 running cheap pump gas.
knifeboy2 is offline
post #4 of (permalink) Old 01-24-2005, 02:01 PM
I doubt that you will see much performance gain if you index spark plugs - usually only racers do it in order to squeeze every possible and miniscule amount of power
RedCJ7 is offline
post #5 of (permalink) Old 01-24-2005, 03:36 PM
[ QUOTE ]
Yep way back in the race car days we used about 6 sets of plugs to get the indexing right for 8 plugs,, and surprising as it may sound with competition fuel mixes it did make a difference. Small but it was noticeable on the scope. [img]images/graemlins/burnout.gif[/img]
GP'n is offline
post #6 of (permalink) Old 01-25-2005, 12:08 AM
Journeyman
DuneCountry's Avatar
We use "indexing washers" on our quads. They are different thicknesses to tighten up the plug in the right spot.
The gap pointed toward the intake port on a two cycle and toward the intake valve on a 4 cycle.
I have never indexed a car engine but I have seen the washer assortment somewhere, I think Summit Racing has them.
DuneCountry is offline
post #7 of (permalink) Old 01-25-2005, 08:01 AM
Waste of time and plugs!!!
did it to a mustang after a dyno run, and got NO differece on the second series of dyno passes.
BurnedBronco is offline
post #8 of (permalink) Old 01-25-2005, 10:35 AM
Gnarly4X's Avatar
[ QUOTE ]
It depends. I know the guys at a local engine shop, they have an engine dyno and the chief engine builder builds mostly V-8s for drag racing, and he does index plugs with gap pointing towards the piston. In a daily driver or non-race applications you probably won't notice any difference.
Gnarls.
Gnarly4X is offline
post #9 of (permalink) Old 01-25-2005, 12:35 PM
I've seen as much as about a 6% HP gain by indexing properly.
Most of the time you can tell where they should point by marking the ground electrode on NEW STOCK ORIGINAL PLUGS THE HEAD WAS DESIGNED TO USE - not aftermarket junk. And it must be torqued accurately to spec. That gives you the guide.
Then most of that time you'll find the open gap is toward the center of the combustion chamber. The ground electrode will be AWAY from the chamber's center.
The ground electrode creates a "shadow" to the flame. The flame has to bend around it, splitting the flame front into 2 waves as it passes. Sometimes when those 2 waves collide on the other side of the electrode it creates spark knock -- harmful ping. That's why sometimes they aren't always pointed directly at the center. In those cases the ideal place is found by experimentation.
Remember -- the intake valve closes long before the spark occurs. After the valve closes the gasses swirl and mix as it gets compressed. Just before ignition those gasses almost stop moving (it's designed to do that, the engineers aren't really crazy.) The spark ignites the mixture and the flame moves across the chamber evenly, creating a nice burn - hopefully without much swirling - you want a straight push down by the expansion.
That's why it's pointed toward the majority of the mixture - the center. (Same reason a Hemi works so well.
That's why multi electrode plugs are just a sales gimmick - too many shadows!
RRich is offline
post #10 of (permalink) Old 01-25-2005, 01:56 PM
Yeah, I should of thought the valve is closed for a long time.
But what about Side Gapping? Fact or Fancy?
Heck, I'm still trying to figure out how Ford put two plugs on each side of the combustion chamber and didn't create an area of intense pressure in the middle causing knock. Must of been the shape of the combustion chamber. [img]images/graemlins/smile.gif[/img] Must work because Audi and others are doing it.
