help me with my brakes please - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-20-2005, 09:38 PM
ok so i bought new calipers, pads, and rotors, all were shot get it all back togother and bleed the brakes but the pedal when i start it up and drive it still goes ot floor. i have no pressure . i have bled the back and the front. spent 20 or 30 minutes on the front and still has good presuure when it is not running but as soon as you start it up it loses all itls pressure. please help i have a road trip tommorow and need these things fixed. thanks ryan
post #2 of (permalink) Old 01-21-2005, 02:17 AM
Rio_Grande's Avatar
Re: help me with my brakes please
Ryan how exactly are you bleeding them? Make sure the petal never hits the floor, and they should pump up/ Are there any leaks anywhere?
Rio_Grande is offline
post #3 of (permalink) Old 01-21-2005, 09:35 AM
dfjeepster's Avatar
I had the same problem with my 93 YJ and it was really puzzling because I had replaced the rotors, drums, pads, shoes and MC. I bled them so many times and flushed all new fluid through and they still didn't work right. I thought it must be the booster but it checked out fine according to the normal tests, it held vacuum, the pedal dropped when the engine was started and it didn't hiss or anything but it just seemed to be the culprit. Evidently it had an internal leak in the diaphragm because I finally replaced it and my brakes worked the best they ever have. Usually when a booster goes bad it causes a hard pedal, but I have since talked to several other people who have had jeep boosters do the same thing. [img]images/graemlins/confused.gif[/img]
dfjeepster is offline
post #4 of (permalink) Old 01-21-2005, 09:40 AM
Grapehead's Avatar
does it have ABS?
did you follow the proper bleeding sequence?
have you tried gravity bleeding it?
what method of bleeding did you follow?
Grapehead is offline
post #5 of (permalink) Old 01-21-2005, 12:26 PM
Aprentice
I had a similar problem with the brakes on my truck when I did and extensive brake job. I did the calipers and rotors, etc... The system woulod appear to bleed out fine but when I went to actually drive it, pedal to the floor. The end problem was I had the calipers on the wrong sides so the bleeder screws were too low to get all the air out of the sytem. I swapped sides, re-bled the system and no more problems.
Buffy is offline
post #6 of (permalink) Old 01-21-2005, 04:31 PM
Had a similar problem with my daughters Mustang....ended up being a bad vacuum booster for the power brakes....go figure....last thing I would have suspected.
