-   -   My attempt at the HEI conversion (https://forums.off-road.com/jeep-short-wheelbase/203626-my-attempt-hei-conversion.html)
ricochet 01-15-2005 07:19 PM
1 Attachment(s)
Well Here it is. I removed my MSD and installed this. Fired fight up. Now I just have to set the timing and take it for a ride. Hopefully this will fix the problem.
http://tellico.off-road.com/wwwthrea...-ignition1.jpg
http://tellico.off-road.com/wwwthrea...-ignition2.jpg
ricochet 01-15-2005 07:20 PM
Re: My attempt at the HEI conversion
1 Attachment(s)
attaching another pic
Aaron871 01-15-2005 09:17 PM
Keith, your missing a romex connector [img]images/graemlins/grin.gif[/img] [img]images/graemlins/grin.gif[/img] [img]images/graemlins/grin.gif[/img]
jeepgod 01-15-2005 09:28 PM
hehehe.. a romex connector.... i now know what that is... hehehehe... and the conduit.. but that looks like you can only have 15 conductors in that size box.. [img]images/graemlins/grin.gif[/img]
John_Strenk 01-15-2005 09:31 PM
Do they make one for the plasic boxes? I thought they were all pipe couplings. I hope he moves all those splices inside the box.
OlllllllOCJ 01-15-2005 10:00 PM
The box is a good idea. I had been looking at those types at Lowe's but found something else at Radio Shack.
I'm with John on the splices, better off inside the box and a grommet would make it perfect.
Actually I don't care much for those type splices and would solder the wires together and use heat shrink. But that should work.
I see that you used a harness for the TFI coil. That makes it cleaner and more vibration proof. Didn't try the fuse holder harness thing huh (that's OK, I will).
Don't see a heat-sink in the pictures, did you cut a hole in the box so that the heat-sink is outside in the cool air?
Hope you don't mind if I steal your pictures (sooner or later).
Dale
ricochet 01-15-2005 10:42 PM
It is actually sitting on a heat sink in there, just can't see it in the pic. Even though the box looks plastic, it is a metal one. I'm not one for soldering anything. I've always used these types of connectors with great success. All the wires will be tapes up nice and tight.
RRich 01-15-2005 11:27 PM
Great idea - the electrical box. Actually the metal box itself is probably enough heat sink. Probably better than a finned heat sink inside the box. That way the heat gets carried outside rather than just heating the air inside the box.
Interesting to note - good crimped connections are actually better than solder - according to Electrical Engineering studies. The crimp "hammer welds" the metals together - an actual molecular merge - without a third metal (solder) between them. But they have to be firmly crimped!
Looks good!
OlllllllOCJ 01-15-2005 11:45 PM
[ QUOTE ]
Not to mention protected from the environment (like the muck and mud that will be tossed up).
[img]images/graemlins/blush.gif[/img] Dirty Dirty
Dale
Jim_Lou 01-16-2005 06:31 AM
Keith, I sure hope that cures your engine problems. Bet YOU do too! [img]images/graemlins/smile.gif[/img]
[ QUOTE ]
The operative word there is 'good', right? Crimp connections done with the $100+ multi-stage ratcheting crimp tools are (or at least used to be) the only connections approved for certain military and aerospace applications.
But that's not the same thing as a crimp done with the $5 do-everything tool from Auto Zone. I've never thought of that technique as acceptable for more than a temporary patch. Too many go bad after a few years of muddy salt water and vibration.
