1971 Buick 455 HEI wiring questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-09-2005, 09:06 PM Thread Starter
Aaron871's Avatar
1. This looks like a self contained HEI unit. Do I only have to hook up the positive wire from the ignition switch to the positive side of the coil?
2. Do I have to ground the neg. side, or is that just for the tack hook up?
3. How do I tell which side of the coil is positive. (the coil is attached to the dist. cap)
4. What is the firing order? Anyone have diagram of the dist and block with the firing order numbers on it?
Aaron871 is offline
post #2 of (permalink) Old 01-09-2005, 09:59 PM
OlllllllOCJ's Avatar
Re: 1971 Buick 455 HEI wiring questions
1. Yes.
2. No. (Yes that's for the Tach)
3. They are labled.
4. 18436572
Click it.
Dale
OlllllllOCJ is offline
post #3 of (permalink) Old 01-09-2005, 10:47 PM
The ground for the HEI system is the mounting screw on the module. Make sure it's clean and tight. No other grounds needed.
RRich is offline
post #4 of (permalink) Old 06-07-2005, 09:01 PM Thread Starter
Aaron871's Avatar
Does this system require a resistor or does it take the full 12 volts?
Aaron871 is offline
post #5 of (permalink) Old 06-07-2005, 09:31 PM
Full 12 volts direct from the ignition switch - use at least a 12 gauge wire to the terminal on the side of the cap marked (+) or Batt - preferably a 10 ga. It's power hungry.
The other terminal is for a Tach.
RRich is offline
