Transmission Failure w/ XJ 4.0L Auto - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-03-2005, 11:14 AM Thread Starter
Hey all, I'm posting w/ this account but what I have is a
98 XJ Classic 4.0L Auto, but was told to post here cause the specs are about the same.
This is what happened, I'm looking for advice asto what might be the cause.
Was pushing 75mph mid highway (about 2 hours driving) and transmission failed. Engine would rev, (and when I got off road would stop/start normally), but the car was effectively in neutral. After pulling over, the transmission did nothing for any gear D/R/12/3 etc. When moving into and out of Park, there would be a light grinding noise. However, I later discovered that it would drive w/o incident in 4L (and the problem persists in 2H and 4H).
Its got 115K on it, 20K since April (when I bought it).
Any ideas/suggestions?
Thanks in advanced,
-Stranded at the girlfriend's house
veitcha is offline
post #2 of (permalink) Old 01-03-2005, 11:52 AM
Re: Transmission Failure w/ XJ 4.0L Auto
First thing to do would be to check the fluid level in the Trans. The simptoms sound the same as if it was really low on fluid. That would be a pretty easy fix. If you have already done that, and the fluid level was correct. what did the fluid look, and smell like?
Olin18 is offline
post #3 of (permalink) Old 01-03-2005, 01:54 PM
GeeAea's Avatar
You've got a transfer case issue. I'm not acquainted with the internals well enough to pinpoint your problem ..probably the lockin ring for 2h-4h.
If your trans was the problem ...you would go nowhere in any t-case position. Check your linkage ..you may get lucky.
GeeAea is offline
post #4 of (permalink) Old 01-04-2005, 01:18 PM Thread Starter
Thanks guys,
I just heard from the shop and they confirmed that it was the TCase. Combination of too little transmission fluid and too much wear. They said likely the planetary gear/ring/lock? wore out which is why it couldn't gear up to 2H or 4H, and it was gear to gear on 4L which is why I could drive it to the shop in the first place.
At least I know now they weren't trying to rip me off (broke down 3 hours from home mechanic).
Thanks again.
veitcha is offline
