TF999 woes/gettin' hot - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-25-2004, 11:54 PM Thread Starter
lomodyj's Avatar
TF999 woes/gettin\' hot
Drove the Jeep today, went about 30 miles and the temp gauge that is installed after the auxilary cooler pegged at 350 degrees. It usually regesters around 160 degrees. The fluid looks good, and there is plenty of it...Anybody have any thoughts on why this suddenly changed? What could be causing it to get so hot?
lomodyj is offline
post #2 of (permalink) Old 08-26-2004, 07:26 AM
Re: TF999 woes/gettin\' hot
1) Pump could be bad (not circulating fluid).
2) There could be a blockage, causing the fluid to not circulate.
3) You could have something broken or damaged inside.
4) Water in the tranny (fluid would be milky and you need to drain a little to see this, won't show on the dipstick)
- When it got hot (or just before) did the transmission act any different (slipping, noises)?
- What were you doing just before this happened (water, mud, high revving, etc)? Did you JUST install the cooler before this happened? If yes, that is telling something.
Just a note, temperatures that high can and will kill a tranny in minutes. If you installed the cooler, then this problem happened, I would suspect a blockage in the cooler. Remove the cooler out of the loop (I know it's a pain) and see if the problem goes away. If it does, bad cooler.
pnut is offline
post #3 of (permalink) Old 08-26-2004, 07:42 AM Thread Starter
lomodyj's Avatar
Seems to be working correctly, no slipping, no new noises.
went on a highway trip this weekend to a friends shop (130 miles away). On friday night his truck broke down, I spent 3 hours sitting beside the road behind him. Had my motor running most of the time...but tranny and engine temps never went up. Installed rear selectable locker on Saturday then drove home. Did not notice any temperature increase on the way home (it was raining like the monsoons and I had no top...may not have even looked at the tranny temp gauge). No off roading this weekend.
No. The cooler has been on for several months.
lomodyj is offline
post #4 of (permalink) Old 08-26-2004, 12:07 PM
is your cooler in the rad. or is it an add-on-one?..........eather way it moght need a good flushing...you might have gotten some "trash" in it.......since i have a 5-speeed i might be talking out of my butt on this one but its worth a shot to look at.
WHTTRASH is offline
post #5 of (permalink) Old 08-26-2004, 01:15 PM Thread Starter
lomodyj's Avatar
Cooler is an add on, sits in front of the radiator. The temp gauge sender is after the radiator, just before it dumps back into the tranny.
lomodyj is offline
post #6 of (permalink) Old 08-26-2004, 03:01 PM
jeeper2's Avatar
Others know more, but this sounds similar to a problem that I had on my truck.
I would check to make sure it's getting lock-up. Slipping could cause it to heat up. Test drive and at high speed you should get lock-up... after which you should not get any (or only a little 1:1) increase in rpms with speed as you accelerate.
jeeper2 is offline
post #7 of (permalink) Old 08-26-2004, 04:05 PM Thread Starter
lomodyj's Avatar
Thanks for the info so far...likely gonna take it to a "transmission" shop tomorrow.
I have a buddy local that has offered up the auto that is in his 2002 TJ partster, anybody know what this is and if it will bolt inbetween my 258 and my NP231? I know I'll have to come up with something for the linkage (TJ-floor shifter YJ-column) but is the rest of it the same?
lomodyj is offline
post #8 of (permalink) Old 08-26-2004, 10:15 PM
Carpal \'Tunnel
wrath's Avatar
Check the gauge, sender, and wiring to make sure it isn't shorting to ground. Or, at least I assume that is the way your gauge works. I'd check to see if it gets pegged when it is shorted to ground.
At about 300 the transmission fluid will turn very dark. At 350 the clutches are usually overheated and will noticeably slip. And you have the sending unit at the input to the transmission.
Anyway, I'd check your wiring. Especially if your ATF looks like it is supposed to. If it really got that hot it'd visibly be dark and smell burnt.
wrath is offline
post #9 of (permalink) Old 08-26-2004, 10:26 PM
Caver Dave's Avatar
Good call Wrath!!... Should be a valid shot since it's the canned answer for folks with overheating engines &amp; electric guages.
Any chance that "selectable locker" required goobering around under the hood....near the OBA...where something or someone (OK...YOU) could have dinged a wire or bent/broke the wire to the sender??? [img]images/graemlins/grin.gif[/img]
Caver Dave is offline
