Sealing headers to block with RTV? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-23-2004, 09:16 PM Thread Starter
Carpal \'Tunnel
knifeboy2's Avatar
Its not quite how it sounds. What I've got are a set of the paper header gaskets that are 1 peice from front to back that I'm installing. In the past with crappier gaskets I've used RTV to help seal and it worked except I didn't do a great job installing the gaskets so I'm redoing them. Should I or should I not put RTV on these before installing them? Will the heat from the engine do what it needs to do to seal these things up? I'm tired of redoing this job.
knifeboy2 is offline
post #2 of (permalink) Old 08-23-2004, 09:26 PM
Re: Sealing headers to block with RTV?
Permatex Copper sealant is made for that application ...
Jaffer is offline
post #3 of (permalink) Old 08-23-2004, 09:52 PM
pontiac58's Avatar
You shouldnt have to seal them with silocone. Make sure your headers are good first off. So headers have that lip around the tube and if that is rusted off a little they will not seal. I forget the name of the gasket company, but they make a really thick spongy feeling header gasket that has sealed every one i have put on as long as the header was good. I have also used with good results manifold gaskets that have the metal on the one side and the paper on the other. No matter what, the headers will leak again. They all do, thats why you will never see headers on my CJ.
pontiac58 is offline
post #4 of (permalink) Old 08-24-2004, 06:51 AM
ecamp55's Avatar
Here's 2 tricks for sealing those pesky gaskets from my old hot rod days.
1. Soak the gaskets in water for awhile, put them on wet and fire up the motor to dry them
2. Spray them good with chrome paint, let dry and install them (I still use this method on my Panhead head gaskets).
ecamp55 is offline
post #5 of (permalink) Old 08-24-2004, 07:07 AM
[img]images/graemlins/tongue.gif[/img] Permatex is all I've ever used on Shivel-A Vee-Ate exhaust manifolds, and as was mentioned, the heavy stuff at the bottom of an old can of "Okie Chrome" paint is also one of the best gasket sealants imaginable. [img]images/graemlins/crazy.gif[/img]
CJDave is offline
post #6 of (permalink) Old 08-24-2004, 07:11 AM
And -- new bolts, and run a tap down through the holes. Wash out the holes with brake cleaner - let dry.
Lube the threads with anti-sieze, use a torque wrench to tighten them down slowly and evenly. Be fussy to keep them all even as you tighten in small increments.
Uneven torque from old rusty bolts is a major cause of header/exhaust manifold leakage and warping.
RRich is offline
