Steering box brace - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-23-2004, 11:10 AM Thread Starter
Steering box brace
In another post I mentioned the problems I had keeping the steering box mount bolts tight. There were several things that I did to contribute to the problem - antisieze instead of Locktite primarily - but another factor was surely the strain put on the bolts by the steering effort. Here are a couple of pictures of the brace I made to take the stress off the mount.
This is the steering box end. There are two 3/8"-16 socket-head bolts that are countersunk into the piece on the right. The other part is drilled, counterbored 3/8" half way through, and tapped.
This is the passenger-side end. It bolts to an unused hole that would hold the steering box mounting bracket in a RHD vehicle.
All stock is 3/4" cold-rolled, so it might also serve as a brush guard and auxillary tow point. [img]images/graemlins/laugh.gif[/img]
Jim_Lou is offline
post #2 of (permalink) Old 08-23-2004, 11:55 AM
Tippy's Avatar
Re: Steering box brace
Looks solid. I ran into the same problem, the bolts kept pulling out of the box. I built a brace and help solve the problem.
Tippy is offline
post #3 of (permalink) Old 08-23-2004, 12:17 PM
You machined that piece up? Great work Jim!
TiminMb is offline
post #4 of (permalink) Old 08-23-2004, 12:21 PM
elusive's Avatar
a 4.0 connecting rod works perfect for this as well.
elusive is offline
post #5 of (permalink) Old 08-23-2004, 12:34 PM
Caver Dave's Avatar
Cool, got one you can send me? [img]images/graemlins/grin.gif[/img] ...seriously!
Caver Dave is offline
post #6 of (permalink) Old 08-23-2004, 12:39 PM
Wow, very nice work, Jim. [img]images/graemlins/40BEER.gif[/img]
You willing to share the blueprints?
Dan 84 CJ-7 is offline
post #7 of (permalink) Old 08-23-2004, 01:56 PM Thread Starter
Dave, I can make one for you, but not right away. The Boss put me on a landscaping project. I still have about 12 tons of rock to haul to the back yard, a Jeep full at a time.
Dan, sure. I'll send a drawing to anyone who wants it, although finding out that a connecting rod will do the job makes me think that it's not worth all the machining.
Jim_Lou is offline
post #8 of (permalink) Old 08-23-2004, 03:04 PM
Caver Dave's Avatar
That's what I was asking Elusive...Did he have a conn rod to send me! [img]images/graemlins/grin.gif[/img]
post #9 of (permalink) Old 08-23-2004, 03:45 PM
He He - perfect timing Jim. I was working on that very thing, came in the house and saw your post.
But mine's a bit different - the box is squared off on a Rubi where that portion is round on others. Needs a different sort of brace attachment point, sorta rounded off square.
And -- a friend recently ripped his box off the frame on the trail -- the bolts didn't let go -- but the entire pod under the frame where it mounts came off - it ripped the 4 welds right off! That pod's only 3/16 thick. He said the welds looked fine on the outside, but they way they ripped apart showed they hadn't penetrated properly.
I'm making a 1/4" plate on each side to sandwich that box to the frame. Then a cross brace like yours.
So far I haven't found any mfgr making a brace specifically for a Rubi - the standard ones won't fit. An opportunity for somebody creative.
RRich is offline
post #10 of (permalink) Old 08-23-2004, 04:48 PM Thread Starter
Rich, when I made that clamp, I machined the perimeter of the pieces first, and then did the drilling and tapping. Then I bolted the pieces together with a 0.010" shim between, and put the assembly on the milling machine to bore the hole. But I could have just as easily made a square or rectangular hole with an end mill.
If you can't find a ready made brace, send me the dimensions of the hole you want and I'll make a clamp for you. You can make the other end and cross bar and weld it all together, right?
Jim_Lou is offline
