Justs quits running - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-18-2004, 09:31 PM Thread Starter
Apprentice
Justs quits running
I have a '84 Cj7, 258, Nutter bypass and a Weber carb. All of a sudden during warm up the engine dies. I can restart it but sometimes it will crank pretty long. This happens multiple times while it's cold. Once it's warmed up it's fine.
It's just as if the ignition's been turned off. But all my gauages stay on. It's getting gas, because I have one of those transparent fuel filters and it's full of gas. I always thought if the ignition module failed it would fail after it got hot.
I'm perplexed. Any help would be appreciated.
Thanks
oldmangump is offline
post #2 of (permalink) Old 08-19-2004, 12:57 AM
OlllllllOCJ's Avatar
Re: Justs quits running
Ahhh well it takes three things... Fire, Fire Water and that other thing the we don't often give credit to - air.
If ya got air (very important), and ya got Fire Water (only $2.XX per gallon these days and going up) then there must be something funny with the Fire it's self (short or broken wires... smashed wires... burnt wires...). Lots and lots of reasons to be funky when cold (all Fords are hehe).
Add a little... someone will chime in.
Dale
EDIT: I like the nic too. [img]images/graemlins/grin.gif[/img]
OlllllllOCJ is offline
post #3 of (permalink) Old 08-19-2004, 07:19 AM
84_CJ7's Avatar
Since it is only happening cold I don't think it is electrical.
Do you have an electric choke? I have a Weber 32/36 and the electric choke on mine has been finicky to say the least. Pull the air filter (cold) and watch the choke operation to make sure it is working correctly. I suspect that the choke valves are not closing and creating enough vacuum to pull the fuel into the carb while it's cold.
Another thing that you mentioned, your clear fuel filter, makes me wonder. Does this filter have the 1 inlet/2 outlet design? It is my understanding that this type of filter needs to be used, with the lager outlet going to the carb and the smaller outlet, sitting at the top, going to the fuel return.
It is usually the simple things that are the cause of the problems. Start with the basics and work your way up. Easy to preach and not always easy to do (guilty as charged).
Good luck
Scott
84_CJ7 is offline
post #4 of (permalink) Old 08-19-2004, 09:43 AM
Modules can fail as they warm up -- especially Ford types. Most fail hot, but that's not a rule. The quit when they feel like it.
First you need to determine if it's spark (a lack thereof) or fuel.
Since you say it's a sharp cut-off, not sputter-sputter- die, then I'd suspect the module.
Next time it happens, check for a spark. If none, try a new module. Even if that's not it, it will be someday, then you'll have a spare.
Check the routing of the coil wire too - don't let it touch anything - look for whitish marks on it where it's been jumping through.
RRich is offline
