D44 Axle shortening - will this work? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-18-2004, 08:34 PM Thread Starter
I have a complete '91 waggy front D44 and the housing from a '79 F-250.
I am planning on using the waggy axles and outers with flat-top knuckles and the F-250 housing.
My questions:
1)Can I use the axle shafts from the waggy connected to the outers for a gauge when setting my new knuckle yokes?
2)What keeps the axle shafts positioned outwards to the hub assbly? I had the drive flanges (snap-locked) on, but it looked like the axle shaft could slide towards the pumpkin?
Thanks!
OregonSahara is offline
post #2 of (permalink) Old 08-19-2004, 10:27 PM Thread Starter
Re: D44 Axle shortening - will this work?
anyone?
post #3 of (permalink) Old 08-20-2004, 08:59 AM
The axel will have a little movement in and out, but not much. I think that it tends to float back and forth a little to keep the center line of the U-Joint where it wants to be.
I don't understand how you plan to use the axels as a guide to set the knuckles. I would measure the Waggy housing and put the Ford housing together with the same dimensions. You can use the distance from the filler plug to the knuckle eye, for example. That should let the axels interchange just fine.
Jim_Lou is offline
post #4 of (permalink) Old 08-20-2004, 01:16 PM Thread Starter
I was thinking of bolting the entire outers (hubs,steering knuckles, and axles) to the shortened housing, and checking the knuckle yoke position by how far the axle end sits in the diff carrier.
post #5 of (permalink) Old 08-20-2004, 04:24 PM
you want shaft length so there all the way into the side gear or locker but give 1/8th of play to keep them from bottoming.
then pound your inner knuckle the C on till it it is almost flush with the end of the tube. i leave about 1/16th".
a snap ring holds the outer shaft tight into the locking hub.
BurnedBronco is offline
