-   -   Hello to all and a Vacuum question (https://forums.off-road.com/jeep-short-wheelbase/197590-hello-all-vacuum-question.html)
disjeep 08-16-2004 12:46 PM
Hello everyone, First time to site definatly not last
My name is mike, a buddy and i just picked up a 87 yj with 258! auto(crap) carter bbd(crap) A/C that acctually works great! We have already redone the brake system, tranny coolant lines, tranny gasket, Hoses (coolant), altenator/belt, crapper bbd rebuild, various electric work, oil, filters etc., all six U-joints, and probably 10 other things that i cant remember or try not to remember. The motor has unbelievable power(compared to my last jeep with 2.5) only complaint is the lopey/bouncy idle under 1000rpm. if i set idle higher it is fine but it wont hold a constant rpm under 1000rpm. I think this is a problem with the vacuum system or should i say maze. Does this sound like a vacuum problem or should i look for something else?
jamz900 08-16-2004 01:11 PM
Re: Hello to all and a Vacuum question
sounds like what was wrong with my jeep, but i just ripped all the vacuum stuff out and put on a weber carb. If you want to get your carter carb and other emmissions junk working right check out this page: 258 site
upalittle 08-16-2004 01:15 PM
Welcome to the board. Always glad to have new jeepers. Participate and you will be rewarded. If you fill out your profile, you might even find that someone in your area could be of help to you. Or you might have information about your area that others are interested in. Again, welcome. [img]images/graemlins/40BEER.gif[/img]
TiminMb 08-16-2004 04:26 PM
There is a solenoid / vacuum pot (solvac) that controls idle speed on some jeeps with bbd's. See if the throttle stop solvac is moving while this occurs. Intake manifold or other joints in the intake could have vacuum leaks. Also, the idle mixture may not be adjusted properly. If emmissions are not a concern, I would unplug the electrical harness from the stepper motor on the back of the carburetor and set the idle mixture with the screws on the front of the baseplate. Use a vacuum gauge to set the best lean idle.
jeepsteve 08-16-2004 04:41 PM
Welcome to the wonderful world the carter carb!
I am still having some of the same problems you are... no easy fix. I just rebuilt the carb and its no better. I have found that the Transmission and Torque converter can cause poor idle problems. I drained and refilled my tranny and TC twice in one day to get the debris out and it helped a lot. The TC wasn't disengaging at idle in other words, it was always pushing the vehicle forward harder than it should therefore it was dieseling at the stop signs more than a poor idle. I finally adjusted my carb to idle at 1000rpms and just live with it til I can afford to replace it.
disjeep 08-17-2004 01:18 AM
jeepsteeve i think you got it on the nose. The crapper auto pulls hard at idle i think the tourque conveter may be the culpret is there any way to know this is my problem. I do have the stepper motor but i would like to get rid of half the wires and emmissions crud if i could. The tranny also leaks, i have already replaced cooling lines, which were obviously no good, and have also done the filter and gasket.
is there an easier way to fix this than swapping in a cummins 4bt and an nv4500, hhhhmmmmmmmmmmm
jeepsteve 08-17-2004 09:33 AM
Keep adding fluid and run it till it dies. I didn't flush the tranny, I think it needs the little sludge to actually make it work right now.... think of the trick used car salesman use to "fix" a worn out tranny... they dump a few handfulls of sawdust in to thicken up the fluid and make it run like new for a few months.
If your fluid gets to low and you take a very steep hill out on the trail, the fluid runs out of the TC, it will lock up without fluid and make your idle problem worse. This happened to me the last time and is what convinced me of the real problem.
Good luck with it.
GP'n 08-17-2004 01:48 PM
Well if you really don't like an auto tranny then,,,,, [img]images/graemlins/deal.gif[/img] I have a DEAL for you.
Too bad we don't know where you’re from,,,,, but I pulled my 87 down (standard) and reinstalled an auto. So I have the complete set up. Again if we knew where you were we may be able to do a straight across trade [img]images/graemlins/grin.gif[/img] .
Now to get real, what I pulled was a BA/10 tranny believe me, you do not want that.
But if you get into serious wheeling you may find you can't live without the auto. Seems like the flavor to go with these days.
Welcome aboard
Now fill out that profile!!!!!!!!!!!!!!
disjeep 08-19-2004 12:37 PM
yeah i think that the auto will be nice off-road, i dont want to swap tranny until i blow something up, i am from Salem MA i will fill out my profile but i am on the boards at work so i dont have much time to do that i need to sign on at home i will post pics and everything too i just need some time.
