A/C Conversion for Heat - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-12-2004, 05:19 PM Thread Starter
Okay, I am trying to do a few more mods with what I've already got now that my idle problem is a little more under control.
The underdash A/C system that came on my YJ has not been used in probably 10 years and the condensor has had a small hole in it since before I got it. Therefore it is of little use as is...
I have removed the condensor to get better airflow through the radiator and capped off the compressor for building an OBA system later. The interior dash components are still in place and the blower works great. Here's my thought....
pipe the existing cooling core (?) behind the dash to circulate water from the heating system rather than freon to give me a secondary heater on those cold mornings and never put my hardtop back on.
Thoughts??
Thanks
jeepsteve is offline
post #2 of (permalink) Old 08-12-2004, 05:43 PM
JeepnGreg's Avatar
Re: A/C Conversion for Heat
sounds like a good idea if it fits
just make sure that with both your heaters on full blast you dont Over-cool you jeep....since running the temp too cool would run you at less than optimum efficiency.
also, would coolant be running through it all the time? if so it may get a lil tooo warm in the cab during the summer.
otherwise a great idea, can never have tooo much heat in an old jeep....except for summmer
JeepnGreg is offline
post #3 of (permalink) Old 08-12-2004, 11:29 PM Thread Starter
In the comfortable warmth of a 95+ Mississippi summer (equal humidity) the motor temp is around 190-210 depending on if its cloudy or clear. I have a feeling that the motor will still run pretty hot even in our winters which ain't all that bad. If I can run the stock heater to defrost the windows on those few really cold mornings, I can run the other unit to keep the rest of me warm. With the half doors, most of the heat stays around my feet pretty well.
Anybody have any knowledge about the little A/C core? I know its pretty small diameter tubing in one end, I just want to be sure it moves enough water through it to stay warm and provide heat, otherwise its not worth it. I can't find any information on the core itself and have not pulled the system from under the dash to look at it.... I'm still in the conceptual stages on this one. I figure a T in the line going into the heater core and a T in the line coming back out through the firewall would be all I need. Maybe a reducer or two to pipe to the A/C core and back but that should be it, right?
Thanks in advance,
post #4 of (permalink) Old 08-12-2004, 11:38 PM
1. Yes, it does work.
2. I did it on my 83 CJ7,
3. I T'd the heater core inlet-outlet,
4. And fed it into the under dash AC unit...
5. It keeps the CJ shirtsleeve warm,
6. Down to -40F in deep cold of
7. The Wisconsin Winters...
8. I say go for it!
post #5 of (permalink) Old 08-13-2004, 04:16 AM Thread Starter
Even better idea.... thanks Leve. I thought I had come up with something pretty novel.... should have known you'd already tried it. Root beer to you [img]images/graemlins/40BEER.gif[/img]
post #6 of (permalink) Old 08-13-2004, 10:05 PM
[img]images/graemlins/smile.gif[/img] Well, Jeepsteve........ on our project CJ-7 we wanted air conditioning for these muggy summers here in Corn Ville, yet we knew and understood that we needed some additional defrosting capability for the fearsome Midwest winters. What we did was buy a box heater from JCW and we built a center section that goes between the seats and which has the box heater built into it. The box heater blows out on each front floor area to warm our feet, and that leaves the stock Jeep heater to deal with the frosted windshield. The heater section we made was also the riser for the after-market console we bought AND the B&M shifter. [img]images/graemlins/cool.gif[/img]
CJDave is offline
post #7 of (permalink) Old 08-14-2004, 07:26 AM
[/ QUOTE ]1. Well, Dave's got a good point.
2. With my system the <ul type="square">[*]OEM heater can be devoted to defrosting the windshield[*]The under-dash unit heats/circulates heat in the cabin.[*]It keeps the windshield/side window completely frost free under the harshest conditions.[*]I would suggest combining it with a windshield wiper modification
[/list]
3. Between the two, the mod works very well.
4. If anyone's interested in Dave's auxiliary heater box,
5. Take a look - at the SnoJeep Heater - .
6. In any case,
7. Either, or any, of these modifications,
8. Are project-worthy...
9. Especially before an impending winter.
post #8 of (permalink) Old 08-16-2004, 10:16 AM Thread Starter
Thanks Dave and Larry... I'm sure glad I don't have to worry about the wiper upgrade for snow. I haven't seen hardly any snow since I moved out of the Great White North 14 years ago. I hate having a top on the jeep at all other than a bikini so summer A/C is not an issue even if it means I sweat like a hog... the hotter the better! The upgrade is strictly for a little more warmth in the winter which can be really harsh for about two or three weeks. [img]images/graemlins/beach.gif[/img] I appreciate all the help.
As always, this board is the first place I come for answers after Google!
