OT Stupid comcast wireless net, help please - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-16-2004, 12:18 AM Thread Starter
We have comcast "cable" (not sure what the offical term is) internet going into a surfboard sb3100 cable modem. You can usually get about 2 web pages to load then you have to pull the power cord out of the back of the modem to reset it so you can get something else to load. It dies all the time and will give you a can not find server message. usually Instant messanger still works but you can't web pages to work. If you try and watch a video your lucky if it last 30 seconds before it stops working and you have to reset. Any ideas it's getting really really old and makes the internet just about worthless.
Jeeper99xj is offline
post #2 of (permalink) Old 06-16-2004, 12:23 AM
Re: OT Stupid comcast wireless net, help please
Might want to check your cable signal strength. If you have your line split and using it for cable TV too, it may be weakening the signal enough to breifly loose the connection. I had 2 separate lines run from the box. One for All the TV's and a dedicated internet line.
Do you have your modem hooked up through a USB port or an Ethernet port? If it's hooked up through USB, make sure it's not hooked to a hub that isn't getting enough power from the power supply, or make sure you don't have the power saving feature switched on for the USB ports.
Dan 84 CJ-7 is offline
post #3 of (permalink) Old 06-16-2004, 10:37 AM
Skip
Sounds like weak signal on cable. Run a direct line from where distribution box enters the house. If that doesn't fix problem call cable company and have them come out and check strength with meter.
post #4 of (permalink) Old 06-16-2004, 11:05 AM Thread Starter
We have tevo could that be screwing up the net? I'm assuming the cable goes straight to the distribution box since it goes though a hole in the floor into the basement (i'd have to pull a ton of ceiling tiles to tell where it goes from there). Guess it's time to get comcast over here. It took me a good 15 min to get 4 web pages to load and 4 IM's sent. I'm about to start pulling out my hair.
post #5 of (permalink) Old 06-16-2004, 12:11 PM
That would be a good start!!! (Just kidding, Andy)
upalittle is offline
post #6 of (permalink) Old 06-16-2004, 04:32 PM
spider10382
I actually work for a cable company. Not comcast its actually charter communications. And dont worry if you have them and dont like it neither do but its a job and I get lots of free stuff so I can deal. Anyways if you need to reboot the modem that often it is either a bad modem or the RF strenght is just way to weak. The front of your modem should have a series of lights. When the internet service freezes does the cable light blink? If it is then it is most likely a rf issue. I dont know about comcast but we do free service calls and I think they do to but that may be your best bet because they can amp the signal right out at the pole. Oh one other question are you running any kind of router? [img]images/graemlins/confused.gif[/img]
post #7 of (permalink) Old 06-16-2004, 04:43 PM
I kind of agree with the last post. Turn off everything (modems and routers generally have to be unplugged). Leave everything off at least five minutes. Turn on the modem, after a couple of minutes at least( book says five) then turn on your router if it is connected then after five minutes turn on you PC. If that doesn't help your problem then try to run a program called Ad-aware 6.0. It's a free download. It will get rid of some spyware on a pc that will surely slow down your PC. That may help some. I run it all the time when everything is starting to slow down. Let us know if that doesn't fix it.
Pauli is offline
post #8 of (permalink) Old 06-17-2004, 11:46 AM
Give comcast a call. I had the same problem after I moved into my new house. They found I had low signal strength due to the previous owner using RG-59 cable instead of RG-6 and having way too many splices. They came out and ran new wire and got rid of some of the splices and everything works fine now.
Ceejay73 is offline
