OT Need help with Ford trouble codes...Please.... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-14-2004, 05:30 PM Thread Starter
jeeperjohn's Avatar
1990 Ford F-150 with a 5.0 Auto trans.
I have:
1) A KOEO Code 84 (EGR vacuum soleniod circuit failure). What do I need to check and how do I do so?
2) A KOER Code 13 (Can't control idle during self test low RPM check) What do I need to check and how do I do so?
3) A have a Constant Memory code 14 (PIP circuit failure). What does this mean, what do I need to check and how do I do so?
I know it's OT, but I have not been able to find any answers.
Thanks in advance
jeeperjohn is offline
post #2 of (permalink) Old 06-17-2004, 11:58 AM
Re: OT Need help with Ford trouble codes...Please
Code 84: follow the vacuum line from the EGR to the fire wall(or fender) there will be a solenoid. Disconect the line that runs from the solenoid to the manifold and check if there is vacuum at the line. If ther is vacuum at the line the solenoid is bad. If there is no vacuum to the solenoid then the line is clogged(very unlikely).
Code 13: is most likely the IAC(idle air control)valve. it is located on the throtle body. If it is stuck(happens a lot due to carbon build up inside or from bad windings in the electronic actuator) the computer will not be able to adjust the idle speed. It is usualy located on the bottom side of the truck TB. http://www.p71interceptor.com/repairs/iac/ has photos of what you are looking for.
jimmythetech is offline
post #3 of (permalink) Old 06-17-2004, 03:11 PM
rick_yj
In the future, you might consider using the Ford forum
post #4 of (permalink) Old 06-17-2004, 04:04 PM Thread Starter
jeeperjohn's Avatar
I tried that also. Is there a problem?
post #5 of (permalink) Old 06-17-2004, 04:17 PM Thread Starter
jeeperjohn's Avatar
jimmythetech, thanks for the help. [img]images/graemlins/40BEER.gif[/img] It never ceases to amaze me that when all else fails I can get help with almost anything here.
post #6 of (permalink) Old 06-18-2004, 12:17 PM
Well we do try our best.
