timing and back firing - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-07-2004, 07:17 PM Thread Starter
hi there
i'm getting to start my 258 back up after about 2 years of sitting idle.
i pumped some oil up in to the engine by taking out the distrubutor and using an electric drill and straight slot screw driver. i then poured a wee bit o' gas in the carburator...needless to say the engine didn't start. i need to redo the timing.
my question though is could the lack of proper timing cause the engine to backfire up through the carb or was that because i poured gas down it?
thanks
patrick
OIIIIIIIO is offline
post #2 of (permalink) Old 06-07-2004, 09:16 PM
Apprentice
Re: timing and back firing
Timing most likely. Mine backfired like a cannon when the timing was 180 out. Made my help have to check his pants since he was under the hood. I told him not to stand there.
lah2420 is offline
post #3 of (permalink) Old 06-08-2004, 01:00 AM
I second the 180* out causing backfire through the carb. Double-check your timing then triple-check it.
Good Luck
blabhern is offline
post #4 of (permalink) Old 06-08-2004, 06:56 PM
Apprentice
I guess I'm slow. I double checked, then had a "mechanic" friend do the triple check. After his second, making it the quadruple check, we discovered it was 180 out. The wife always said I was hard headed.
lah2420 is offline
post #5 of (permalink) Old 06-08-2004, 07:19 PM
OlllllllOCJ's Avatar
Do a search for TDC and/or distributor installation, maybe even "where should #1 be"....
It's all been covered a few times in the last few months for different motors, but they are all the same in that aspect.
Got Depends? [img]images/graemlins/grin.gif[/img]
Good Luck
Dale
OlllllllOCJ is offline
