OBD II code help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-04-2004, 06:37 PM Thread Starter
OBD II code help!
OK, got the nifty software to get my codes, and I have no idea what they mean. Can someone tell me what this means:
Powertrain 0442 Evaporative
0456
The computer will not let me turn the light off, says the problems must be fixed.
Thanks
Paddy Whacker is offline
post #2 of (permalink) Old 06-04-2004, 07:45 PM
Re: OBD II code help!
1. Was the code Powertrain 0442, or
2. Was it P0442?
3. You've got an emissions leak.
4. Is your gas cap loose?
5. Try removing only the NEGATIVE battery cable,
6. Then while it's removed,
7. Turn the ignition to RUN.
8. Let it sit about a minute,
9. Turn the igntion to OFF,
10. Then reconnected the battery after about 10 minutes.
11. See if that clears the code.
post #3 of (permalink) Old 06-04-2004, 09:57 PM Thread Starter
Leve, I was running without the air cleaner box for a few days, finally slapped on a paper cone filter on that someone recommended. The light triggered a day later. Might have been that, but I will disconnect and see.
post #4 of (permalink) Old 06-04-2004, 10:12 PM
jamgood96's Avatar
What were you running for a filter for those few days before you slapped a paper cone one on?
jamgood96 is offline
post #5 of (permalink) Old 06-05-2004, 09:40 AM
GeeAea's Avatar
The evap/purge code won't show right away. It is a "pending" code that will only turn on the light after so many start events. This is since the purge cycle, to test the integrity of the evap system, only occurs at start up.
Buy the FSM for your jeep. It'll be the best money that you will have spent on it. All this is explained in detaill.
Check the vacuum hoses to all that hardware that hangs on the driver's side of the intake.
Never run without an air filter unless you consider the engine "null and void", since doing so, if not already, can suddenly make your engine "null and void" if it sucks in something big. Even the introduction of small abrasives (silicon, sodium) sand blasts your throttle body, intake and intake vavles ..given the velocity that they're introduced into the engine. This stuff, some of it anyway, ends up in your oil ..where the stuff the size that can't be filtered out ...just spins around passing through the filter and knocking off lead and tin in your bearings ...and iron off your cylinder walls.
This is why it is recommended to change your oil more often in dusty conditions.
GeeAea is offline
