tranny problems and engine troubles - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-31-2004, 02:36 PM Thread Starter
My cj5 has developed two new problems in the past couple of days. One is that it randomly dies going down the road, it'll start back up after a couple of seconds if i just leave it in gear and let the speed turn the engine over, but the tach goes to 0 when it dies. This makes me think its an electrical problem, but i cant find any shorts or anything along the way. its a gm hei on a 383. My other problem is with my transmission. Its a t176. It is starting to let me not go into second or third unless i double clutch it, and even then its relatevly tuff. It doesnt ever grind, but it just wont let me go into the gear. first and 4th are never a problem. Sometimes it also wont let me out of third when i come to a stop unless i really pull hard on the shifter. any ideas what this would be from?
farmerbobrainy is offline
post #2 of (permalink) Old 05-31-2004, 03:28 PM
Re: tranny problems and engine troubles
Hi Matt
Not sure what year your 5 is but if its new enough your engine death problem sure sounds the same as my 7 when the Duraspark Ignition Module is on its last leg prior to its death. I'm not familiar with CJ-5's I might be wrong but that would be my advice........worth less then 2 cents actually. Good luck
SUA SPONTE
Grunt
Jeepgrunt is offline
post #3 of (permalink) Old 05-31-2004, 05:41 PM Thread Starter
well i got rid of all the factory ignition when i put the sbc in, so its a chevy hei dist. could the module in that going bad cause this?
post #4 of (permalink) Old 05-31-2004, 11:37 PM
i had the same problem with my 258 and it turned out to be nothing more than loose battery cables. eyeball those.
YJOwnr22 is offline
